Hi,
So I'm looking to build a new system mainly for high-end gaming, watching 4k hdr content and coding.
This is the build I'm currently looking to get and would appreciate any advice on how to improve it:
PCPartPicker Part List
CPU: Intel Core i9-13900KS 3 GHz 24-Core Processor ($729.99 @ B&H)
CPU Cooler: Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler ($119.95 @ Amazon)
Motherboard: MSI MAG Z790 TOMAHAWK WIFI ATX LGA1700 Motherboard ($259.99 @ B&H)
Memory: Corsair Vengeance 64 GB (2 x 32 GB) DDR5-6600 CL32 Memory ($222.19 @ Amazon)
Storage: Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($169.99 @ B&H)
Storage: Samsung 870 QVO 4 TB 2.5" Solid State Drive ($203.93 @ Amazon)
Storage: Seagate BarraCuda Pro 8 TB 3.5" 7200 RPM Internal Hard Drive ($215.00 @ Amazon)
Video Card: MSI RTX 4090 VENTUS 3X 24G OC GeForce RTX 4090 24 GB Video Card ($1935.99 @ Amazon)
Case: Fractal Design Torrent ATX Mid Tower Case ($199.99 @ B&H)
Power Supply: be quiet! Straight Power 11 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply
Operating System: *Microsoft Windows 11 Pro OEM - DVD 64-bit ($149.99 @ Adorama)
Total: $4207.01
Approximate Purchase Date: Sep/Oct 2023.
Budget Range: 3.5K-4.5K.
System Usage from Most to Least Important: High-end gaming, watching 4k hdr content and coding.
Are you buying a monitor: No, will be using my s90c OLED.
Parts to Upgrade: Everything.
Do you need to buy OS: Yes.
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts: Doesn't really matter.
Overclocking: Maybe.
Your Monitor Resolution: 3840 x 2160.
Additional Comments: No RGB and no water cooling.
And Most Importantly, Why Are You Upgrading: It's been a long time coming. My current system is getting really old and looking for a high-end, future-proof build.
Total: $4207.01
