First of all I want to say sorry if this is posted in the wrong section of the forum if it is please move it.
OK So i want to build my own PC and i want some advise on parts my budget is £500 or bellow. I wont be doing alot of gaming but I do need a powerful PC. I was thinking of an Amd processor 4-6 cores or something like that.
If you could suggest me the following.
Decent Motherboard.
Power Supply.
Cooling kit such as water cooling
graphics card
case
Not sure what else i need to be honest probably need more but i cant think I have the HDD sorted I have a 750gb sata laying around and i plan to put a 80gb ssd for the OS.
Thanks in advance.
Also are AMD reliable and are they good never used them before.
Decent Motherboard.
Power Supply.
graphics card
case
Thanks in advance.
