Hello Everyone
I am a first time poster and a first time server builder so sorry if I sound a little green.
So here is my situation: I am running 3 x 1 TB external HD's to my macbook (running plex) which is hooked up to my TV. I am running out of space and decided the best way to go would be to build a file server and run it to my macbook with the intention of expanding to other media computers in the future.
Here are my needs:
- 8 x 1 TB hard drives in a RAID 5 array
- something decently quiet
- hopefully spend less than 1200 dollars before hard drives
- as power-friendly as I can get
As I have never built a server and don't know much about them, I was wondering if people here could give me some advice. I'll try to explain what I think I need and hopefully you can correct me if I am way off.
So I will need:
1. a case with 8 x 3.5" bays (maybe something like this: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129021 )
2. a raid controller
3. a motherboard
4. A processor (nothing fancy - like 2 GHZ duo core?)
5. about 2 GB RAM
6. Power supply
7. Some sort of server software
8. a PCI Gigabit Adapter to run files over ethernet to my media computer
Now can someone explain what sort of motherboard, gigabit adapter, and RAID controller I would need as that is the most confusing part for me. Please be as specific as you can.
Also, what sort of software do you recommend? I will just be running files over ethernet to my computer so I don't need anything fancy. I have never used Linux so I don't know if that would be the best option for me.
Lastly, if I am running 8 TB drives, what would you recommend for a power supply. Is 500 W enough?
Thank You
Here are my needs:
So I will need:
3. a motherboard
5. about 2 GB RAM
6. Power supply
Thank You
Yummmy...
