Basically trying to build a high performance machine at low cost.
Can I put this together and it work?
FX 8320
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113285
GTX 560 SE 192bit 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187203
MOBO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135318
I'm researching how to build a PC and as far as I know if you have the MOBO and components with matching sockets they should work. Is it that simple?
I know there are things like Bios that need to be updated but I've personally never done that and am not 100% on what it entails.
Does the northbridge of the MOBO have anything to do with the processor or Video card compatibility?
FX 8320
MOBO
