Hi, I need help getting part together to build myself a new gaming rig. Here is what I am aiming for.
Budget: No more than $3000
Use: Mainly gaming, with a little of web surfing and some Microsoft Office work.
Gaming: I am mainly aiming to build this for Battlefield 3, Starcraft 2, and Diablo 3. I want this to be able to run those game at max setting or at least close to.
Special Need: I want to run SLI in the future.
Going to be OC in the future.
I want to stay with the case that i use.
My monitor native resolution will be 1920 x 1080 at 60 Hz.
http://accessories.us.dell.com/sna/productdetail.aspx?cs=19&c=us&l=en&sku=320-9270
My Build so far.
Computer Case: COOLER MASTER HAF X RC
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Motherboard: GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128506
Video Card: 2X EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
PSU:
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Ram: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Hard Drive 1: Crucial M4 CT128M4SSD2CCA 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
Hard Drive 2: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Cooling: Noctua NH-D14 120mm & 140mm SSO CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
OS: Microsoft Windows 7 Professional Upgrade
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116714
Now, i got several questions that need be answer.
1) what is the different between I5 2500k and I7 2600k? Please explain in detail
2) With the GPU i pick, is there a better set up for cheaper price? Or Better single card that will be able to run SLI for cheaper price in the future?
3) Will the cooling i have be enough if i want to OC the system in the future?
4) Will i be needing addon card for internet?
Thank you for your help.
My Build so far.
PSU:
Main Post updated!
