Hi Guys,
I posted a previous thread but i think I named it incorrectly and didn't get much response. I did get some help from a few users but didn't get all the answers I needed.
I'm putting together a p.c for gaming and this is what I've come up with so far (thanks to the help of some registered users)
My only question now is the memory. I will be running a 32 bit system but was advised to get 3x2g ram sticks? Is there not a 4g limit on 32 bit?
Spec as follows:
Motherboard: R 4,645.00
http://www.comx-computers.co.za/MB-AP6TDV2-ASUS-P6T-Delux-V2-LGA136-7-mb-on-board-on-board-o-f-lear-CM-pu-2039.php
Asus Intel LGA1366
MB-AP6TDV2
ASUS P6T-Delux V2 ; LGA1366/i7 mb ; on-board on-board on/off/clear CMOS switch , fanless heatpipe design , 16+2 phase power design , 3-way , nVidia
SLI / ATi coressfire ready ; intel X58+iCH10R , 6x tripple channel 2-phase DDR3 2000 ( support XMP upto 1.69v ) , 7 x s-ata2 with raid
0/1//0+1/5/10 ( 6 x SATA + 1 x e-SATA ) , 1 x parallel ata133 , on-board ADI 2000B Dobly Digital live 7.1 audio with coaxial+optical S/Pdif out +
dual gigabit lan + ieee1394a ; 2x pci , 1 x pci-e(1x) , 3 x pci-e 2.0 (16x+16x+1x or 16x+8x+8x ) - 1 x PS2 only for kb
Processor: R 4,040.00
http://www.comx-computers.co.za/CPU-i7920-Intel-Boxed-Core-i7-920-Processor-2-66GHz-Quad-Core-Information-Price-Buy-Cheap-p-24522.php
Intel Core I7 Quad Core Socket LGA1366 Processors
CPU-i7920
Product Summary
Intel® Boxed Core™ i7 920 Processor - 2.66GHz Quad Core, Socket 1366, 8MB L3, 4.8GT/s QPI, 45nm, x64 Support, 3 Year
Memory: R 2,830.00
http://www.comx-computers.co.za/ME-C2G3X16X9x3-Corsair-TR3X6G1600C9-XMS-3-with-heatsink-3-x-2G-048mb-k-pu-1891.php
DDR3-1600 240pin PC3-12800
ME-C2G3X16X9x3
Product Summary
Corsair TR3X6G1600C9 , XMS 3 , with heatsink , 3 x 2Gb/2048mb kit - support Intel XMP ( eXtreme Memory Profiles ) , ddr3-1600 ( PC3-12800 ) , CL9 ,
1.65v - 240pin - lifetime warranty
Graphics Card: R 5,930.00
http://www.comx-computers.co.za/SC-XGTX285B-Xfx-GX-285N-ZDB-Black-edition-geforce-GTX285-Graphics-card-Information-Price-Buy-Cheap-p-24833.php
SC-XGTX285B Xfx GX-285N-ZDB Black edition, geforce GTX285 Graphics card
XFX 16x nVidia PCIE SLI
SC-XGTX285B
Product Summary
Xfx GX-285N-ZDB Black edition, geforce GTX285 , SLi support , Pci-E 2.0 16x , support HybridPower , 1Gb/1024mb 512bit DDR3 , support DirectX 10 +
shader model 4.0 +FP32 HDR + 16x AA ; max resolution 2560x1600 , HDCP Compliant , RoPs : 32 , 159Gb/sec memory transfer , 240 stream processors @
1.476Ghz ( pixel shader engine + vertex pipelines ) , core/memory : 690/2600mhz , 2 x dvi ( with dvi to d-sub + dvi to hdmi ) , HDTV tvout
Power Supply: R 1,885.00
http://www.comx-computers.co.za/PS-C750TXE-Corsair-TX750W-power-supply-unit-Information-Price-Buy-Cheap-p-24937.php
PS-C750TXE Corsair TX750W
Product Summary
Corsair TX750W , Eps12V , ATX 12V V2.2 - 750w ( 12v : 720w ) , nvidia SLi ready , 80PLUS certified for energy saving , 24pin ( 4pin detachable ) ,
with active-PFC , 4 x 8pin (2+6) PCI-E power connectors , 1x 140mm thermal controled fan ; with OCP, OVP, OPP, SCP, UVP - 5 years warranty
P.C Chassis 1: R2852.62
http://www.prophecy.co.za/ikonik-smooth-chassis-without-black-p-34372.html
IKONIK RA X10 SMOOTH, ATX CHASSIS without PSU, BLACK
[A3_IK-X10-K]
SPECIFICATIONS
Model name Ra X10 Smooth
Case type full tower
Dimension (W x H x D) 220 x 572 x 606
Color Black / silver
5,25” drive bay 6 (incl. convert kit for 3,5’ external device)
3,5” internal drive bay 8
Expansion slots 8
Side panel Solid with noise absorbing foam
Material Entire aluminum (3.0 mm front door / 1.2 mm body construction / 2.0 mm material thickness construction bars
I/O panel top (dual e-SATA / quad USB 2.0 / one IEEE 1394 / one audio)
Cooling 1 x front 120 mm incl. LED + 1 x 120 mm optional / rear 1 x 140 mm / rear bottom 2x 80 mm / optional 1 x 120 mm bottom
Mainboard support µATX / ATX / CEB / E-ATX (extended-ATX)
Tool-less design One-touch removable front drive-bay cover / removable MB-tray / one-click HDD installation
Protection Rubber op HDD and PSU railing for anti-vibration and noise reduction
Maintenance Removable and washable filter, HDD cage and MB-tray
LED Front
Design Diamond-cut front door/ rotatable & removable anti-dust cover / EPS 12V PSU support/ 3D curve AL top cover
DVD Rom: R 335.00
http://www.take2.co.za/electronics-lg-gh22ls30-22x-lightscribe-dual-layer-dvd-writer-black-ivory-4021609.html
LG GH22LS30 SATA 22x LightScribe Dual Layer DVD Writer - Black / Ivory
LG GH22LS30 , 22x , Lightscribe , Sata , black+beige bezel , support SecurDisc technology ( password protection , digital signature , data
integrity check , PDF copy protection ) , super-multi : DL dvd+R , dvd±r/rw + dvd-ram + cd+/-rw ; 2mb - retail pack
So that's it so far. I haven't done any research on hard drives and would appreciate any recommendations.
Could someone let me know about the ram issue?
Spec as follows:
Asus Intel LGA1366
MB-AP6TDV2
CPU-i7920
Product Summary
Memory: R 2,830.00
ME-C2G3X16X9x3
Product Summary
SC-XGTX285B
Product Summary
Product Summary
[A3_IK-X10-K]
SPECIFICATIONS
Expansion slots 8
LED Front
DVD Rom: R 335.00
I'm basically building a new machine but I'm going to keep some of the hardware I currently have:
