HELP, building my own PC
jade_glam
Commendable
Sep 28, 2016
Hi there,
I plan to build a computer and have found the parts that (I think) I want and need. Could you please have a look through and let me know what you think? Comments and suggestions are welcome since this is my first born and my computing knowledge is minimal. I will simply use this for Microsoft PPT, Word, Excel, some basic software to edit images (contrast, saturation, brightness etc.), and to go online (no gaming etc). This has simply been a fun project for me.
Looking forward to your feedback!
Ps – The cheaper the batter, providing we don’t compromise on necessary quality.
CPU (95.99)
Intel Core i3-6100 3M 3.7 GHz LGA 1151 BX80662I36100 Desktop Processor
http://www.newegg.com/global/uk/Product/Product.aspx?Item=2MN-0004-00002
Has integrated GPU (Intel HD Graphics 530).
Motherboard (42.99)
ASUS H110M-A LGA 1151 Intel H110 HDMI SATA 6Gb/s USB 3.0 uATX Intel Motherboard
http://www.newegg.com/global/uk/Product/Product.aspx?item=N82E16813132646
SSD (29.99)
Silicon Power Slim S55 2.5" 120GB SATA III TLC Internal Solid State Drive (SSD) SP120GBSS3S55S25
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16820301259
RAM (26.99)
Crucial 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Desktop Memory Model CT2K4G4DFS8213
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16820148858&cm_re=8gb_DDR4_ram
Power supply (31.99)
CORSAIR CX series CX430 430W 80 PLUS BRONZE Active PFC ATX12V & EPS12V Power Supply
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16817139026
Power supply cooler (TBC)
Not really needed apparently.
Power lead
Guilty Gadgets - 5m IEC C13 Mains Power Cable UK Plug Lead Cord For Kettle Pc Monitor and Printer
https://www.amazon.co.uk/Guilty-Gadgets-Kettle-Monitor-Printer/dp/B00B066S3G/ref=sr_1_2?s=computers&ie=UTF8&qid=1471912714&sr=1-2&keywords=power+cable+kettle
Wireless Card/Adapter
TP-LINK TL-WN851ND Wireless N300 PCI Adapter, 300Mbps, w/WPS Button, IEEE 802.1b/g/n, 64/128 bit WEP, WPA/WPA2
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16833704040&cm_re=wireless_card
Case (20.99)
DIYPC P48-BK Black USB 3.0 ATX and Micro-ATX Mid Tower Computer Case with 2 x 120mm Blue Fans (Pre-installed)
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811353082
Reviews talk of the CD drive. I have an external one, but would you recommend I buy an internal one?
I am not set on this case, I don’t really mind what it looks like, as long as it is practical.
Display, mouse, keyboard (25.00 bidding)
LG HD TV monitor + Logitech keyboard and mouse (wireless)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=222257303481#ht_500wt_1204
Seems like a good deal, but the eBay auction ends soon. I need to check if the screen has a HDMI input to match the motherboard, waiting for the seller to reply. In the case that it does not, would it be worth buying the converter rather than the display with HDMI input? As these seem quite expensive.
