https://www.pccomponentes.com/configurador/F53f8cEc4
Hello i am a novice when it comes to pcbuilding, and i need help with a few questions.
I need to know if this setup will work correctly.
I dont know if the power supply i chose was good enough for the setup (not sure if it was calculated properly).
I also want to know if it will be good for 3d sculpting and modeling with maya.
Finally i would like to know if at the price point of my setup is it worth it or should i look at something else with the same price.
All feedback is helpful
Thank you for your help
