Help building wife's computer
kaesin
60
I'm trying to figure out exactly how/what to put into my wife's computer. She has the CM 690 NVIDIA Edition case and, well, that's it.
Right now she plays WoW, but she wants the ability to play any MMORPG game that comes out in the near future and also play them extremely well. I heard WoW utilizes quad core now, but I haven't seen it yet since my i7 build is waiting for paypal to authorize. :p
Anyways... I'm thinking about building off of a Q series? Or even an i7... would prefer the price range to be around $1000ish.
I'll browse around and see if I can't come up with any parts myself, but I'm drawing a blank on gaming builds for a 1k budget. Any help would be GREATLY appreciated.
Thanks.
fullmetall
1,698
1k budget build shouldn't be hard for a gaming computer on a quad.
Q9650.
Gigabyte UD3P for crossfire or the Gigabyte UD3R for non crossfiring,
ASUS P5Q Pro. either of those boards.
Sapphire HD 4870 512mb
Western Digital 340gb or western digital black 500gb-640gb.
Case, already have.
Could get a simple stock cooler since you dont need oc'ing but, if you do, Arctic cooling 7 pro or S1283 preferrably + retention Bracket.
PSU 500w PC Power Cooling.. would send out the page links but, someone will always have something else to say and bring in more page links to another product, so, theres a list i got going.
fullmetall
1,698
Acer's 22inch is cheaper than that at 2500:1.
but, thats not a bad one aswell.
if its to much, can switch the sapphire down to a 512mb.
4870 either way is good enough, even a 4850 is good enough.
kaesin
60
Currently what I have is
Case: CM 690 NVIDIA Edition (Already bought)
CPU: i7 920
Monitor: Asus 21.5" 2ms
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051
Motherboard: Asus P6T
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
Video Card: EVGA GeForce GTX 285 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130442
OS: Vista Home Premium 64-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
PSU: Corsair 850TX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
RAM: OCZ XMP Ready 6GB (3GB x 2GB) DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388
CPU Cooler: Noctua NH-U12P SE1366 120mm SSO
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608007
Ending price: $1,565.92.
Any helpful hints? This is for the wife's build. It's a little over the $1k but if it'll be worth it, I'm going to go for it. If it'd be better to go with a Q series, then I'll go with a build based off of one of those instead of the i7 assuming they would both last for a while.
