HELP, buying a PC case is soo hard x|
SkyBlade9000
17
Im looking to fit the new gtx 980 ti graphics card plus an ATX motherboard... and im so confused in what case to buy to support this..
Cases are an easy option, but you have to know what you are looking for. You need ATX, so no mATX cases. You need good airflow to support your high end case.
If you don't know what to buy, then pick what's popular that fits within your budget. The Corsair 300R is a great all around case that wont break the bank and is very popular.
