Help calibrating an ASUS VE228H monitor?
kkopplien
I Recently bought an ASUS VE228H monitor a couple months ago, and am having trouble making
it look right. It seems that the backlight is very dim even at its highest setting. Also, i can't seem to
get the colors to look right. I don't know if this makes a difference or not but my monitor is hooked
up to a ps4 via HDMI. Could anyone that owns this monitor tell me the settings that they currently
use? Which mode you use, Brightness, Contrast, Saturation, Color Temp etc? The more
descriptive the better, and to anyone that can help me out, it is GREATLY APPRECIATED 😀
Hooked it up to a pc and looked decent, but using a monitor with a pc for web browsing makes it hard to adjust colors/ contrast etc for gaming .I think it just has to do with my calibration not being correct. I was hoping someone owns this monitor and could tell me if they find the monitor dim or not.
This seems to be a decently popular monitor so I am hoping someone who owns it, and uses it for gaming could tell me the settings they use that creats the best picture. I am at a point where I am looking at different monitors because I can't seem to fix this.
I have 3 of these monitors and i find the best setup is as follows
- Splendid Menu [Theater Mode]
- Color Menu [Brightness 90 - Contrast 80 - Saturation 64 Skin Tone {Reddish} - Smart View OFF]
- Image Menu [Sharpness 19 - Aspect Control {Full} - ASCR {OFF}
That's the setting that I find the best. It might not be the same for you.
Hope This Helps
Reactions: Visehrad
