Hi, i need a hand in calibrating my Q6600 (b3) 😀
Mobo: Maximus Formula
Memo: Corsair DDR2-800
I followed the guide in here (great guide btw), but i'm finding problems following the calibration part.
These are the steps i did and the results:
Computer Case Covers = Removed
Computer Case Fans = Manual 100% <- The Antec900 control the fans through with my TPII 480W, they are running at high, 3rd setting.
Computer Frequency = 1.6 Ghz (used 8x200)
Connectivity Status = Offline
CPU Fan = Manual, 100% <-- I dont have the option to control it in the bios, but i saw it running at full 12xxrpm (its a Noctua 1200 over an Ultra120 eXtreme).
CPU Internal Thermal Control = Enabled <- dont have in my bios, does it have another name?
Enhanced C1 Control (C1E) = Disabled
PECI (If Equipped) = Enabled <-dont have in my bios
Windows Programs = Closed
Speed Step (EIST) = Disabled <-dont have in my bios
Vcore = Manual 1.25
Ambient Temp is 22c
Now, i record the bios temps and here is when my dubts starts.
CPU temp is 46c.
I reseated the CPU and changed the thermal paste.(my ultra is lapped, but cpu not).
Lets continue, i bootup up and ran speedfan, the hottest core is 23c; CPU is still 46.
Crystal CPUID gave me a 3d which is a 61.
so TJunction Max 100c - 61 = Tjunction 39
Tjunction hottest Core should be Ambient (22c) + 10c +/- 3 = 35c ?
39 vs 35, i'm not picky..but!
From now, how do it continue? should i correct the Tcase? or the tcase is correct and the hottest core should be corrected by 15c? i'm confused here and obviously, i dont want to burn anything
I was planning to install the stock HS and measure everything again, i dont know what to think about that temperature difference between TJunction and Tcase.
I download every program i know and all gives me more less the same tcase!
Edit: Coretemp gives me a hottest core temp of 40c, which is almost the 23+15 =38c that speedfan gives me.
Heelp?
Vcore = Manual 1.25
Ambient Temp is 22c
CPU temp is 46c.
Heelp?
