I InfernalPhantom Commendable Jun 8, 2016 77 0 1,630 Jun 8, 2016 #1 So I have some difficulty figuring out if this power supply would work...(And Yes I have a 6 pin PCIe power connector) Power Supply: This is the graphics card I will buy: http:// Other Computer Parts (i7 4790,etc) http://
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jun 8, 2016 Solution #2 Yes that PSU can run it . Just make sure the card will fit. Upvote 1 Downvote Solution
I InfernalPhantom Commendable Jun 8, 2016 77 0 1,630 Jun 8, 2016 #3 Thank you very much for your opinion! Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Jun 8, 2016 #4 Yes as long as you have the physical space to fit the card (which you very likely should) that PSU will run that card no problem. Upvote 0 Downvote
I InfernalPhantom Commendable Jun 8, 2016 77 0 1,630 Jun 8, 2016 #5 It will fit nice and snug as you both mentioned 😀 Upvote 0 Downvote
