Help, cant boot with iGPU after replaced VGA card
Rizky_2
Commendable
Aug 31, 2016
4
Hii, i have problem with my pc, i can't boot to OS with iGPU always restart after boot screen (asus),. But before i using VGA card i can boot with onboard vga, then 2days ago i want sell my vga card so i replace it and connect vga connector to onboard the problem began to emerge.
Before that i uninstalling the graphic driver, and try reseting bios setting to default. But cant fix my problem, always restarting after asus boot screen.
Btw my spec
ASUS H81m-e
i3 4130
8GB ddr3.
Can someone help me ?
run windows in vga resolution mode, it´s an option of the windows safe mode. Try installing intel update utility and update the graphics driver
It should work, so some issue in Windows is preventing it likely.
You could try SAFE MODE (Google for how with your version of Windows).
If that works:
1) run DDU http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
2) then let Microsoft install drivers for the iGPU. If it's not Windows 10 you can run the Intel software updater (you can for W10 too but it's not needed). https://downloadcenter.intel.com/
Other:
Some issues may be related to UEFI mode. If you never changed this in the BIOS then it's likely not the problem.
1) resetting CMOS is the same as resetting factory defaults AFAIK
2) If he was on the wrong GPU (looking for PCIe) he shouldn't see anything on the screen. He sees a boot screen, so there appears to be some issue once Windows starts up.
I'll try soon, , i hope is not power supply issue.
Not work trying boot to safe mode still restarting. But it's Work now,. I'll try Replace cmos battery and reset bios to default, it still not working, but I'll try reinstaling windows it works now. Maybe cuz is driver problem ?, But thx all. It works now.
