Help! can't close cpu cover on motherboard
Lord Ruffy
29
As said above. I have the msi 797 gaming 9 ac motherboard and I'm trying to attach i5-4690k.
It's aligned correctly, I just can't lower the hook without some force and then not all the way. I don't want to break anything
To close it, you have to use force, it will push back on you, if you have it all aligned correctly you should be fine to use the force and close it down.
Latest posts
