[Help] Can't decide on monitor.
InvisSoul
17
This is the last piece of my system that I will be ordering very soon and I just can't make up my mind and would like some help.
I'd like a 22" but not stuck to that size. I don't want to spend more than $250. There will be some casual gaming probably FPS if anything. Also graphic work so color accuracy is a good point and just general computer use web, browsing etc..
So I had in mind at first:
ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen 16:9 Full HD 1080P LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051
also
Acer H213H bmid Black 21.5" 5ms HDMI Full HD 1080P Widescreen 16:9 LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009157
or for a bit more...
Dell S2209W 22" Flat Panel
http://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=320-7438
I've never owned an lcd except in my notebook and I'm spoiled with an Ezio at work but cannot decide what would be the best for the best money for home. Help!! Thank you
The OP should be aware, though, that the 2209WA is limited to only 1680x1050 resolution. Full HD resolution would not be part of the equation.
Ok, now I really need some help between these two monitors, just not sure which is better than the other (other than resolution)?
S2209W
or the,
2209WA
http://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&s=bsd&cs=04&sku=320-7825
What is the difference between these two. I'm going to buy one or the other and right now just at looking at the specs I like the 2209WA even though the S2209W has higher resolution. I'm looking to buy this asap.
The 2209WA is much better. It is an IPS panel --- very accurate rendering of colors, and the viewing angle is very generous. It's extremely rare to find an IPS panel at this price range (they are usually in the $500+ category). Don't confuse the 2209WA with with the 2209W model, which is a TN panel. Those have very narrow viewing angles and inaccurate color rendition.
