Well, The pc was working alright, today morning turned it off by the power button, an hour went by, and when I tried to turn it on the screen where you choose if you want to get into bios by pressing a key would stay for like 10-15 seconds, then it would enter bios automatically, no options would load, just a text saying gigabyte and the background colors, and after 10 seconds or so it will turn off, not sure what the problem could be, video is alright, and i tried a cmos battery reset but it didn't work, i would try reinstalling bios but im sure you need to enter bios to update-change it, also, pressing any key while on the selection screen won't do anything ( i mean in the one where you press supr to enter bios)
Please, any help is appreciated, and it's not my pc.
beforehand, Thanks!
beforehand, Thanks!
