help cant find a descent power supply expect this corsair HX 850watt
nizaryos
22
hello
i got my build one month ago still keeping it in the box cause i didn't find a descent power supply i looked desperately 🙁 everywhere in my area until i found this corsair HX 850watt i dont know if it is gold or silver but i think both are good ,my question is it compatible with my build
my build
core i7 5820k
16gb ddr4
couldn't find a gtx 960 so i got gtx 970 strix
board x99-A asus
plz help
Any good quality 500W supply or greater is compatible with your build.
If the power supply is not "Haswell Certified", disable the C6 and C7 sleep states in the BIOS. You really don't need these anyway in a desktop computer.
The Corsair HX 850 is a good quality supply, and it supports the Haswell sleep states:
http://www.corsair.com/en/blog/2013/may/haswell-compatibility-with-corsair-power-supplies
You can get this if you like, or choose any Tier 1 or 2 supply over 500W from this list:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
I would suggest the EVGA Supernova G2 750 if it is available in your area.
