HELP!!!!!!!!!!!!!! Casing for my PC build!!!!!!! PLEASE HELP!!!!!!!!!
Mar Allen
81
I am looking for a casing on my PC build and also please teach me on how to choose a casing for my PC.
SPECS:
FX-6300 6-Core Processor
EVGA 600 B1 80+ BRONZE
ASUS M5A97 R2.0 AM3+ AMD 970
Corsair Vengeance 8GB (1x8GB) DDR3 1600 MHz (PC3 12800)
EVGA GeForce GTX 950 (I will buy 1more of this to have an SLI)
I also want that this case would last for me a long time, because I may upgrade the specs but not the case. I want that I can setup this for gaming.
make sure you get an ATX case, therefore most of the motherboards you will only ever come across will fit.
also choosing a case is down to personal opinion.
if you want a quiet gaming machine, the fractal designs define r4 or r5 is a great choice.
if you don't care abount noise, then you can go wrong with a nzxt h440 or s340.
for a case, you mainly want enogh drive bays(HDD and SSD) so you can add more down the track, and also if you want a case that can fit a dvd player or burner, then you will need to make sure it has a 5.25 inch bay/s in the frount, and i would not recomend the nzxt s340 & h440 if you require a dvd drive.
but if you don't care you cant realy go wrong with the NZXT's case.
For me, the noise is such a bad thing. So i'll gonna be choosing between the r4 and r5.
So can you suggest me which is better for the quietness and can you please tell me the comparison between the two.
