• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Help choose flashdrive 128gb
Leyha
174
hello everyone can someone help me?
im lookingfor 128gb usb 3.0 are ya guys have recommend?
before i have flashdisk Sandisk Ultra flair CZ73 32GB, this flashdisk is very fast and i love it but.. this is very hot if i oprate it about 5-30min it is very imposible to touch because very hot
and can someone help me choose 128gb flashdisk? better i buy sandisk CZ73 or CZ48? or other?
thanks you for help!
mrmez
Splendid
I have some of those, they do get hot.
I don't think the heat can be avoided with fast USB 3 drives. All I can suggest is get something bigger with more surface area to cool down. Or get something slow.
The smaller Sandisks have a reputation for getting very hot. I have both the Sandisk Ultra Fit and the Samsung Fit. Based on touching the metal they seem to get about equally hot, but the Samsung's plastic is better positioned to protect you from the heat. And according to reviews the Sandisk seems to suffer more heat-related failures (mine has worked fine for 3 years). Performance of the Samsung is actually a bit better than the Sandisk. Aside from heat, both perform very well.
https://www.amazon.com/Samsung-Flash-Drive-MUF-64BB-AM/dp/B017DH3O5A
If you want best performance, I'd go for the CZ88 (Extreme Pro). It's about the fastest USB 3.0 flash drive out there that doesn't resort to using a SSD controller. Unfortunately it costs 2x as much per GB. (The CZ80/CZ800 is a nearly as good and better priced, but the biggest version is only 64GB.)
Similar threads
