[Help] Choose the right PSU
O762
26
That PSU you linked is 430w? and one 460 requires at least 450w, so that can't run two of 'em.
But yeah, I would recommend corsair as well.
yasio
57
Ok but its a 430w and the GPU company advise a 450w minimum. But they also tell that I need a 12v. 24amp rail. Are you sure this is gonna be enough (I have a a core 2 quad q9300 I want to oc it just a bit and a standard atx MOBO socket LGA775). BTW thanks for the answer !
O762
26
I don't know tbh, but they are two separate rails, so I doubt that they would be the same as one 12v36amp...but someone can correct me if I am wrong. :)
