Hello,
My current system build consist of the following specs and I need help choosing a graphic card. I am not an intense gamer and the most intense game as of now that I play is Diablo 3. Only thing is that I am a multi-tasker so I would like it if the graphic card can handle multiple application at once such as two games open at a given time or even three in the rare cases.
AMD FX 8320
8gb DDR3 Ram
1. Does the GDDR5 ram that comes with each card affect performance significantly? If it doesn't have enough ram, will the card use the system's ram?
2. The following three cards is around the same price range so which one will givesme the best performance for its cost?
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2652129&CatId=7387
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2941929&CatId=7387
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=5400618&CatId=7387
3. On the lower end of graphics card, will this be more worth it?
http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=4501123&pagenumber=3&RSort=1&csid=ITD&recordsPerPage=5&body=REVIEWS#CustomerReviewsBlock
4. Lastly, if the above cards are not worth it, can you please recommend a card that is under $170.
AMD FX 8320
8gb DDR3 Ram
