HELP choosing a GRAPHICS CARD
damianklimek
22
I have this computer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03531711&tmp_task=prodinfoCategory&cc=ca&dlc=en&lang=en&lc=en&product=5296841#N504
All the specs are located there. I would write them out for you but I don't know whats important.
I want to play games like Battlefield 3 on Ultra with steady 60FPS. I do have a i7 3770,12gb of ram, but a horrible GPU Radeon 5750.
Can you please help me find a good graphics card that's compatible with my system's motherboard etc. plus I have windows 8 so I don't know if that matters.
I was thinking about the 7850 or the 660, I've never opened a computer before but I have watched videos. Is it easy to replace the graphics card and for that card I think the power supply too?
I don't want to spend over 300 dollars in total.
That may or may not work. You'd need to check and see how many PCI-e connectors your PSU has. If it only has one, that limits your options a bit. The 660Ti requires 2 6-pin PCI-e connectors, the 7850 only requires one.
