Hi,
I'm currently looking to buy a laptop for a member of staff to use on building sites to do 3D scanning with an Artec EVA https://www.artec3d.com/portable-3d-scanners/artec-eva
1. What is your budget? Around £700, but i'm willing to pay more if you think a more expensive one would be more suitable
2. What is the size of the notebook that you are considering? 15" will be fine
3. What screen resolution do you want? 1080 will be fine
4. Do you need a portable or desktop replacement laptop? Portable
5. How much battery life do you need? As much as possible, preferably with a battery that can be changed quickly, not built in
6. Do you want to play games with your laptop? If so then please list the games that you want to with the settings that you want for these games. (Low,Medium or High)? No
7. What other tasks do you want to do with your laptop? (Photo/Video editing, Etc.) Just 3D scanning with an Artec EVA scanner and processing data as fast as possible with Artec Studio software
8. How much storage (Hard Drive capacity) do you need? 1tb will be fine, all data is transferred to the server after use
9. If you are considering specific sites to buy from, please post their links. I don't mind
10. How long do you want to keep your laptop? I would hope that it would last for 5 years
11. What kind of Optical drive do you need? DVD ROM/Writer,Bluray ROM/Writer,Etc ? Not needed
12. Please tell us about the brands that you prefer to buy from them and the brands that you don't like and explain the reasons. For this laptop i really don't mind, i'm open to anything that suits the task best
13. What country do you live in? UK (England)
14. Please tell us any additional information if needed. I'm told that they use Artec Studio to process the data, and this is the most CPU intensive task it does, so i need a laptop with enough processing power for that (I think it uses a lot of RAM too). It would help if it was quite a durable laptop too, as the member of staff who uses it can be quite clumsy, however its not essential as we do have a harness for it
Thanks!
Thanks!
