Help Choosing a Monitor!
Evoked
5
So my old monitor cut out so its time to get a new one.
Please choose one from this site as this is where i buy all of my parts in New Zealand
http://www.computerlounge.co.nz/components/componentlist.asp?parttypeid=435&t=15
My budget is 200-270, maybe could push it if its REALLY worth it
Also i heard IPS is the best? is this correct?
and also whats the best cable to use, VGA, DVI or HDMI?
The monitor will be mainly used for Gaming and watching videos
Thank you in advance
note: you can sort the list from lowest to highest price so its easier to see the ones in my price range
any connection involving VGA is the worst way to hook up all the monitors. All the other options will produce the same quality. To make it easy I would go for the DVI-D to DVI-D. it's the only option that can do 144hz
First = DVI
second = HDMI
third ( the worst ) = vga
First = DVI
second = HDMI
