Help choosing a network adapter.
canubetrusted
46
Hi,
I am on the lookout for a cheap and reliable network/wifi adapter for my computer. The following specs are what I am looking for:
1. Dual Band
2. Monitor mode supported
3. Packet injection supported
4. Interface is PCI/PCI-E
MERGED QUESTION
Question from canubetrusted : "Help choosing a network adapter."
One time is enough, and bumping your thread doesn't help your case either. This is a site that is primarily staffed by volunteers, someone will get to your question eventually. Bumping and spamming your question will only get you banned.
Do not do it again.
Ethical hacking and penetration testing.
The bigger question is are these parameters available on the market because I haven't found anything.
I forgot to mention it needs to be compatible with Kali Linux.
All I want is a network adapter supporting Kali (and win10 if possible) that doesn't use up my USB ports and supports monitor mode and packet injection. I am doing a course so Wireshark won't be too helpful just because I won't be using it as far as I know.
