Hi,
I recently upgraded the CPU, Motherboard, and other components into an ancient (11 years old) case with an equally ancient PSU. I now want to get a good PSU to go with the rest of my build.
The new specs are:
CPU: i5-9600K
Motherboard: Asus Prime B360M-A
RAM: Corsair Vengeance LPX 16GB (1x16GB) DDR4 DRAM 3000MHz C16
CPU Cooler: Antec C400 Glacial
SSD: Western Digital Green PC 240GB M.2 SATA III (WDS240G2G0B)
Case Fan: Cooler Master 120mm Fan
The following old components remain:
A DVD-RW Drive
2x 160GB Seagate Barracuda 7200rpm drives
1x 1TB WD Green 5400rpm drive
PSU: iBall LPE223-400 (power rating image below)
I intend to get the following components over the next few months (or even years in the case of the RAM)
1x M.2 NVME SSD, and I will probably retire 1 or both of the 160GB Barracudas.
2 more fans
A max of 3 more sticks of 16GB RAM. (I will probably stick with a total of 32GB for the next year or two.)
NVIDIA Geforce GTX 1660 Ti Graphics Card - I will most probably get one of the 1-click OC ones, like the GALAX.
1 WLAN PCI-E Card
I would have a maximum of 3x USB drives connected at any point in time.
I'm using the OuterVision Expert Power Supply Calculator, but have a few questions:
1. What % of TDP should I use in the calculation? Why is 90% recommended?
2. Does the calculator account for power drawn at boost frequency or do I have to increase the frequency or overvoltage parameters?
3. The GTX 1660 Ti has a base clock of 1500 MHz, but a Boost Clock of 1785 MHz. The OC setting uses a 1800 MHz clock. What parameters do I set in the expert calculator for Core clock, Memory clock and Overvoltage?
4. Why is the recommended PSU Wattage 50W above the Load wattage?
5. With the assumptions I'm making, I'm getting a recommendation of an 850 VA UPS. My current UPS is 600VA. What happens if I don't upgrade it? Will it trip in case of power failure or just reduce the battery life?
6. All the PSUs seem to have fans on the top. My case doesn't have a grill on the top panel. I'm assuming that this isn't a problem because the air is blown downwards and out through the rear?
With the values I used, OuterVision recommends a 550W PSU.
Here are the power supplies that are available in the 550W to 600W range:
1. Antec VP600P - Rs 3189
2. DeepCool DN550 - Rs 3035
3. Corsair VS550 - Rs 3300
4. Cooler Master MWE550 - Rs 3665
5. Antec Neo ECO NE550M - Rs 4215
6. Corsair CX550 - Rs 4460
7. Cooler Master MasterWatt 600 Lite - Rs 4747
8. Thermaltake Smart BX1 RGB 550W - Rs 4990
9. Corsair CX650 - Rs 5059
10. Antec Earthwatts Gold Pro 550W - Rs 5885
My budget started at Rs 2500 and is currently at Rs 4000. So the last 5 are outside my budget but I am willing to consider them if the others aren't the right choice.
The new specs are:
CPU: i5-9600K
A DVD-RW Drive
2 more fans
1 WLAN PCI-E Card
