I’m looking for help with a new case. It’s been years since I bought one and I’m quite baffled. I’m looking for something with plenty of room to work in, sturdy construction, excellent filtration with not too many non filtered gaps, that’s as quiet as possible. I listen to music a lot. I’m considering some basic liquid cooling. It will be in the same room as a coal fire. I have lots of very fine dust, that gets in everywhere.
My old case is probably somewhere between a midi and a small full tower. Aside from being rattly, my new graphics card makes things cramped and almost hits the drive bays, and when I got a larger cpu cooler after the last upgrade, I had to remove the side fan and cut away the mount. I either need something slightly larger, or just a different shape. Current case measures: H 54 x L 47 x W 20.5
Some smaller cases claim to be able to handle large radiators, but the pictures show no hard drives. Then there are some huge towers, that will take loads of hard drives. I want my graphics card not to be shoe horned in, somewhere to put 2 hard drives, a couple of SSDs, an optical drive or two (for now, decreatly hidden if pos), and the option to be able to add a couple of radiators in the future. I don’t want it to be the size of a double decker bus, but midi would be too small. Any ideas?
So far, I’ve looked at: Phanteks Ethoo Glass & Luxe Glass, Thermaltake View 71, Be quiet! Dark base pro 900, Corsair 780t, and many others.
Hoping for some recommendations.
ASRock 970 extreme 4
AMD Fx 8350
EVGA GTX 1070 Ti
16gb
EVGA 1000 T2
Samsung Evo 250gb
2xHDD
2xOptical
AMD Fx 8350
EVGA GTX 1070 Ti
16gb
EVGA 1000 T2
Samsung Evo 250gb
2xHDD
2xOptical
