At last I've decided to buy a new system, this is the setup I have planned:
E145-7830 :: EVGA GeForce 7900 GTX / 512MB GDDR3 / SLI / PCI Express / Dual DVI / HDTV / Video Card $479.99
TSD-160M4 :: Maxtor / DiamondMax 10 / 160GB / 7200 / 8MB / SATA-300 / RoHS / OEM / Hard Drive $89.99
CP1-AM2-4800 :: AMD Athlon 64 X2 4800+ 2.40GHz / 2MB Cache / 2000MHz FSB / Socket AM2 / Dual-Core (Windsor) / Processor with Fan $689.99
M452-2822 :: MSI K9N SLI Platinum NVIDIA Socket AM2 ATX Motherboard / Audio / PCI Express / Dual Gigabit LAN / S/PDIF / USB 2.0 & Firewire / Serial ATA / RAID $154.99
O261-5136 :: OCZ EL Dual Channel 2048MB PC5400 DDR2 667MHz Gold Memory (2 x 1024MB) $199.99
T13-1076 :: Coolmax / CW-650T / 650-Watt / ATX / 120mm Fan / SATA-Ready / SLI / Power Supply $149.99
It's $1760 total at tigerdirect.com
But I need your help. Is everything compatible? Do my choices make sense (price, futureproof, etc)? Should I go with socket 939 which is a bit cheaper?
Thanks a lot for the help.
