G
Guest
Guest
Hey everyone,
I built my first PC over the Christmas break and am extremely happy so far. I've been using the integrated graphics and would like to step it up to discrete.
I've been looking and researching but it's all so confusing! I'm usually pretty good at deciphering all the specs but I'm at a bit of a loss here.
I think I would like to go with AMD Radeon.
I will use it for just basic everyday internet/email stuff, but I also will use it for AutoCad/Inventor drawing & renderings, and moderate gaming now and then. However, when I do play games, I wan't them to look good with high resolutions and good fps.
I like the AMD Radeon for it's EyeFinity thing. I'm a huge fan of multiple monitors, so an AMD card with plenty of outputs would be great.
Budget is sub $150.
I've been looking at this:http://www.newegg.com/Product/Product.aspx?Item=N82E16814150534
What do you think?
Also, I'm confused as all get out with the naming and numbers... 6790,6750,6770??? What's "better?" I know that sort of depends on what I want to do with it, but any insight as to what I should look at would be greatly appreciated.
Budget is sub $150.
What do you think?
