Help choosing gpu and ram for skyrim
jsprint
I need a graphics card and ram and will mostly use for playing skyrim and some other not so graphic intensive games. (civ, TF2) unfortantly i am on a very tight budget of $130. any suggestions?
EDIT: my resolution is 1280x1024
clutchc
Ambassador
If you plan on staying at that low of resolution, you should be fine with something in the HD 6750 range.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=100006662&isNodeId=1&Description=hd+6750&x=0&y=0
Or a GTS 450 if you prefer Nvidia...
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100006662&IsNodeId=1&Description=gts%20450&bop=And&Order=PRICE&PageSize=20
I'm guessing most games will play at max settings with those cards at that resolution. Spend the left over cash on RAM. You only need 4GB to play most of todays games.
clutchc
Ambassador
Although a single 4GB stick of memory won't allow dual channel operation, there is evidence that it isn't all that much of a setback. But being somewhat of a skeptic, I prefer going dual channel. And you're assuming his board will accept DDR3.
