Help Choosing Motherboard !!!!
Zuber Khan12
113
6
18,595
That isn't the best PSU to go for with the 8320. Get a tier two class B unit from this http://www.tomshardware.co.uk/forum/id-1804779/power-supply-unit-tier-list.html.
What is your budget for the motherboard?
A good budget friendly board for the Am3+ platform is always the ASUS M5A97 R2.0.
I dont have any specific budget all i want is a motherboard which can handle all this thing nicely ,and i guess this ASUS M5A97 R2.0. is in my budget
^ it will handle a 8320 & a 270x easily mate with some spare headroom.
For a 500w its the best PSU on there at the price easily.
There is not a lot of upgrade room on it if you ever wanted to go for say a r9 290 GPU in the future it would struggle.
Fairly sure it would manage a 280/280x though & a gtx970 easily.
The CX is a better PSU than the vs if you prefer the corsairs.
so why people are saying that go for 600watt PSU ?? and this is 500watt PSU so whats the difference ?
But thanx mate you are a Expert 😀
you aslo from india ?
People overestimate component wattage & underestimate PSU wattage output.
This is a failsafe way of doing things but can lead to putting you over budget when money is tight.
Give me an hour or so mate - I'll rig a power meter upto my fx8320 build with 280x just do you can see how much power it actually uses.
these reading taken at the plug
stock fx6300
idle load 120w
full load cpu 242w
turboduo 280x oc full load gpu 380w
whole system stressed 560w
fx6300 oc at 4ghz
idle load 120w
ful load gpu 380w
full load cpu 260w
whole system stressed 582w
take the stock one ,allow for 80% efficiency on the psu
works out to 448w power wide system draw of 448w including 3.3v /5v /12v lines
a good 500w would run this setup mate with a 280x - no headroom for overclocking at all though.
the 270x draws pretty much 120-140w less than the 280x so err on caution & call it 120w less & your system (fx 8320 with r9 270x ) is pretty much going to max out at 340w full system draw even under 100% load stress testing.
seeing as the seasonic has over 400w on the 12v rail alone then it will do the job absolutely fine mate.
I was just going to suggest as you have no interest in overclocking,that you could save some money & go with this board
http://www.flipkart.com/gigabyte-ga-970a-ds3p-motherboard/p/itmdt9h6w2wsfg2c?pid=MBDDT9H6W2WSFG2C&otracker=from-search&srno=t_5&query=am3&ref=c9f5a5a2-0097-4b68-83ae-6e1fab157df8
the m5a97 is better but prob not worth the extra to you personally if you're not going to push every last bit of performance out of it.
This would even allow you to throw in a half decent aftermarket cooler which will perform a lot better than the one amd supplies
http://www.flipkart.com/deepcool-gammaxx-200/p/itmd9hkatppgpy5y?pid=COLD9HKAARXXSRAH&icmpid=reco_pp_same_computeraccessory_cooler_2&ppid=COLDH22W6ZUWBC5D
as long as your case is big enough??
Woh.. thats a Hell lot of info for a PSU ... you are a PC GEEK 👍. and a savior of my money too 😀 thanx ...
and i am buying a normal case or suggest me some :)
Hi mate,I dont know why I put 6300 above for those readings when its a 8320
also my 280x is bios & volt modded so runs a lot more power than a standard card.
case wise,there are too many,did you have one in mind??
I would suggest a case that has at least a 120mm intake fan & a 120mm exhaust rather than 80/92mm fans
8 cores run warm & a half decent case is a necessity imo.
most of the coolermasters are decent from the k280 upwards you wont go far wrong for budget cases.
depends where youre buying from ,I know over in india you have very limited choices sometimes.
k280 looks nice xD ... thanx man http://www.ebay.in/itm/Cooler-Master-K280-USB-3-0-ATX-Mid-Tower-Gaming-Case-/180978756437 .
any more suggestion ?
budget wise the k280 is hard to beat mate,you need to add in a 120mm exhaust fan though to the price
corsair 200r ,plain looking but a firm favourite with budget builds - hard to fault tbh,will fit any components & comes with very good intake & exhaust fans prefitted
http://www.ebay.in/itm/Corsair-Carbide-Series-200R-Black-Steel-Plastic-compact-ATX-Mid-Tower-Case-/281508558397?pt=IN_Computer_Components&hash=item418b37b63d
thank you very much K280 look more nice .. plus cheap
Hey .. mate thanx for all your information :) but now i got a change to get R9 280x in 15k xD . on of my friend who live in USA is coming this march . so my question is should i go for R9 280x ? and its is worth it ?
the 280x is definitely worth it mate 9thats like 160 pounds sterling so is a good price imo
All I will say is iof yovue already bought the 500w psu it will be close to the limits,you wont have any headroom at all for overclocking etc,
If you dont have the psu yet then Id look at a 550-600w to be on the safe side for a little more headroom.,
yeah i dont buy PSU yet ... suggest my one but in budget hehe....
wow.. thats a nice PSU and costly too.. are you sure mate 500w is not enough ? i mean , i am not going upgrade or overclock any thing atleast for 5 year lol
yes fx 8320 ... ok it means i have to go for OCZ ZS Series 650 Watts PSU . nothing less then this .
and whats the difference r9 280 or r9 280x, because i am getting R9 280 even more cheap check this
1. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8927265&CatId=7387
2. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8927267&CatId=7387
which brand is good XFX or Sapphire
