I made a pc rig few days ago:
i3-4130 or i3-4150
GA-H87M-D3H
CMZ4GX3M1A1600C9
N300
WD10EZEX
(integrated graphic card)
Which of this PSUs should i get?
XFX ProSeries 450W Core Edition V2 Full Wired(lots people suggested me this psu)
Cooler Master Thunder B600 Alimentatore 600 W(i think it's not the correct name)
Thermaltake Munich 430W
Thermaltake Berlin 630W
Are they haswell compatible? Or do they work with an haswell or haswell-refresh CPU anyway?
On the manual of the gigabyte mobo is said that there is an option that allows you to toggle the C3/C6 mode: are they referring to C6/C7 state of the CPU (haswell)?
Should i disable this option or set it to auto to make those psus compatible or has nothing to do with?
Please answer all question in your reply
Thanks
P.S. For the first period i' ll use the integrated graphic card
i3-4130 or i3-4150
GA-H87M-D3H
CMZ4GX3M1A1600C9
N300
WD10EZEX
Thanks
