Help choosing the right memory.
radaevia
16
Hello, my computer is already being built as i write this message, im only missing memory sticks which i didnt pick yet.
This is the computer (mainly for gaming):
1. Gigabyte Z77X-D3H
2. Noctua NH-D14
3. i5 3570K
i think the noctua d14 requires me for a Low profile sticks ...
i want a total 16gb of ram and the memory should be good quality, fast and good with OC.
These are my options according to the store current stock:
2x8GB G.Skill Ares Dual Channel CL9-9-9
2x8GB G.Skill Ripjaws-X Dual Channel CL9-9-9-24
4x4GB G.Skill SNIPER Edition Dual Channel CL9-9-9-24 (Low Voltage)
4x4GB Corsair Vengeance Blue LP Edition CL9-9-9-24\
and some other kingstone sticks
i really prefer using 2 sticks of 8GB over 4 sticks of 4GB because of the OC.
G.skill ares is a good choice?
The difference between 1333 and even 2133 is only noticeable in synthetic benchmarks. You might buy a frame/second with the faster RAM, so I wouldn't rely on your RAM to do too much for you with regard to gaming. Of course the higher speed RAM will require little to no overclock, but an OC on the RAM, in my opinion, is not even worth the risk for what you get out of it. It's either high risk or low risk with the same outcome: little return.
InvalidError
The Ivy Bridge CPUs are intended for use with 1600MHz memory.
As far as OCing memory goes, you will only get 1-2% performance improvement in real-world benchmarks between 1333MHz and 2133MHz so very-high-performance RAM is one of the least cost-effective investments you can possibly make, not worth spending extra on it unless you have already maxed-out everything else. I would simply go with the lowest latency 1600MHz DIMMs I feel comfortable paying for.
InvalidError
I would say Ares (or any other model from a reputable manufacturer) 1600 10-10-10.
9 cycles / 1333 = 6.75ns latency
10 cycles / 1600 = 6.25ns latency
So the "higher latency" (10 cycles) 1600MHz RAM actually has 0.5ns lower latency on top of 20% faster burst rate, no reason to go with the 1333MHz version.
InvalidError
You can get 1333 too, it does not matter all that much. As we said before, there is only 1-2% performance difference between 1333 and 2133 in most real-world applications, not worth losing sleep over it if you cannot get the 'ideal' RAM for whatever reason.
InvalidError
It makes no difference if you overclock a K-chip since you are going to OC the CPU by changing the CPU multiplier while leaving the RAM at stock clock.
The main disadvantage to quad kits is you have no room to add more RAM later without throwing out some DIMMs.
radaevia
16
Ok, thanks all!
I took some time reading and narrowed my choices based on your suggestions and my store's stock to 3 final options, first 2 are 1600 and the third option is 1333:
1. 4x4GB G.Skill Ares Quad Channel 1600MHZ
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231547
2. 4x4GB Corsair Vengeance Blue LP Edition 1600 MHZ
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820233196
3. 2x8GB G.Skill Ares Dual Channel 1333MHZ http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231556
Added links to the exact models.
What should i pick?
radaevia
16
I really dont see any point getting more then 16GB today, even 8GB is overkill to most or all the games around.
I really wanna make my pick based on a more reliable, stable and quality ram.
And again, thanks!
