I'VE DONT SOME RESEARCH AND I'VE CHANGED SOME THINGS, SO TAKE A LOOK TAKE A LOOK AT MY NEW LSIT OF MY COMPONENTS I WANT IN MY PC, THAN TAKE A LOOK AT MY OLDER VERSION (THE OLDER VERSION IS UNDER THE NEW ONE)
Hello,
I am new to this website, and forums. I need help on which motherboard to choose, I am building my own gaming pc, with a lot of features and I don’t know if my motherboard will support all of them. I will not be overclocking.
I am looking for a motherboard with the nForce 680i chipset. Price is not an issue, and I have many components that I need my mobo to support.
Motherboards that I am interested in:
Asus Striker Extreme
EVGA 680i A1 or T1
Gigabyte GA-N680SLI-DQ6
Any others you suggest?
I’ve heard many bad reviews on the Asus Striker Extreme with problems on the BIOS, could someone tell me what the BIOS is bcuz I have no idea. They said they had problems with the BIOS when they overclocked, and since I am not going to overclock will I still have the same problem?
(NEWER VERSION; SCROLL DOWN FOR OLDER VERSION)
(Interface card) $250 [www.tigerdirect.com]
- Bigfoot Networks Killer Gaming NIC Card - Model M1 Gigabit LAN
(Video Card) $730 [www.tigerdirect.com]
- BFG GeForce 8800 Ultra OC / 768MB GDDR3 / SLI Ready / PCI Express / Dual Link Dual DVI / HDTV / Video Card
(Sound Card) $180 [www.tiger direct.com]
- Creative Labs Sound Blaster X-Fi Xtreme Fatality Platinum
(Power Supply) $370 [www.directron.com]
- Thermaltake Toughpower 1200W ATX 12V and EPS 12V Computer Power Supply W0156RU, Active PFC, CrossFire and Quad GPU Ready, w/ 140mm Fan
(Processors) $1150 [www.tigerdirect.com]
- Intel Core 2 Extreme QX9650 Processor EU80569XJ080NL - 45nm, 3.0GHz, 12MB Cache, 1333MHz FSB, Yorkfield XE, Quad-Core, OEM, Socket 775, Processor
(Case) $200 [www.newegg.com]
- Thermaltake Armor Series VA8003SWA Silver ATX Full Tower Computer Case w/ 25CM Fan - Retail
(Hard Drive) $190($380) [www.directron.com]
- 2x Western Digital Raptor 150GB SATA Hard Drive WD1500ADFD, 10000RPM, Super Fast 16MB Cache. OEM
(Motherboard) $300 [www.newegg.com]
- GIGABYTE GA-X38T-DQ6 LGA 775 Intel X38 ATX Intel Motherboard
(Memory/ Ram) $574 [www.newegg.com]
- CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1800 (PC3 14400) Dual Channel Kit Desktop Memory
(Optical Drive) $35 [www.tigerdirect.com]
- Lite-On LH-20A1P SuperAllwrite DVD Burner - 20x DVD±R Burn, 16x DVD±R Read, 8x DVD+RW, 6x DVD-RW, 8x DVD±R DL, 12x DVD-RAM, 48x32x CD-R/RW, Black
(Operating System) $140 [www.directron.com]
- Microsoft Windows XP Professional x64 Edition 64-Bit Operation System Software, Model: ZAT-00094. 1 Pack. OEM
(OLDER VERSION)
Dual SLI BFG 8800 GTS OC2 320MB
Creative Sound Blaster X-Fi XtremeGamer Fatal1ty pro
Thermaltake Toughpower 1200w
Intel Core 2 Extreme QX6850 3.0ghz
Western Digital Raptor 150GB SATA 10,000 RPM 16MB Cache
Corsair Dominator 1066mhz 2GB (2 x 1GB)
Asus PhysX P1 Accelerator Card
Bigfoot Killer M1 NIC
Windows XP Pro 64bit
As you can see I am putting alot into my system and I need a mobo that will support all of this, mainly in the pci slots, which mobo have enough pci slots to allow to install of these on it, suggestion? 🙁
THANK YOU
Hello,
EVGA 680i A1 or T1
(OLDER VERSION)
THANK YOU
