Help choosing upgrade for cpu
liftwaffe
Commendable
Jan 4, 2017
I'm currently having the cpu pretty much always run 100% and wondering if I can get some input on what would be a good cpu upgrade. Thanks in advance.
So my currents specs are:
Motherboard: MSI A88X-G45 gaming
CPU: AMD A8-6600K APU with Radeon(tm) HD Graphics
GPU: GeForce GTX 1060 3GB
RAM: 16GB
Storage: 1TB HDD
OS: Windows 10 64-bit
For INTEL:
If you want to upgrade to intel Skylake, you need to look for new motherboard (LGA 1151) it only support DDR4 so it means you need to upgrade you RAM as well, for CPU I would recommend you to choose i5 6600k or i7 6700k if you want something good for multi tasking.
For AMD:
For AMD I would recommend you to use AMD Vishera FX-9590 4.70GHz, socket is AM3 so it means you need to upgrade you Motherboard.
If you only need CPU, you could choose between these two:
1. AMD Godavari A10-7860K 3.90-4.0Ghz 4-Core Processor
2. AMD Kaveri A10-7870K 3.90-4.10GHz 4-Core Processor
PS: Sorry for bad english :)
