Help Choosing win7 32 bit or 64 bit
GameATwill
44
Hello i want to know that which version to install for exact 4 GB RAM
my specs are
Processor: intel i3 2100
Memory: 4GB ddr3 @ 1333 2x2 Kingston
the PC is mianly used for gaming purpose
thanks in advance
I vote for windows 7 64 bit.
1) Using a 32 bit OS, you will be able to see only about 3.5gb, not the full 4gb you can see with a 64 bit os.
The 32 bit os needs to reserve some space for hardware areas that the 64 bit version does not.
2) Windows 7 is more secure than the 32 bit version.
3) Windows 7 64 bit will run apps with out any degradation. Emulation is not really the right word. Only old 16 bit dos programs like the original civ 2.42 will not run
4) Ram is cheap, a 8gb upgrade does not cost much. and can help with some aspects of gaming:
http://blog.corsair.com/?p=65
5) If you are already running XP or vista, buy the upgrade package for windows 7 instead of oem. The price will be similar.
With upgrade, you get both...
thanks i have one more question am i going to need special games version that support 64 bit or every modern game supports it?? :??:
With upgrade, you get both 32 and 64 bit dvd's. Upgrade is also considered as retail, giving you ms support and transferability to a different motherboard.
Every modern game is built to run on both a 32 bit os and a 64 bit os. Game vendors want the maximum potential market.
thanks 64 bit then 😀
