help chosing?
What are the best mobo to consider is determined by how you will use the machine, what features you need, if you're planning on using AMD or Intel, if you will seriously overclock, and your budget. With out knowing this it's impossible to make recommendations, which is why aevm asked the questions he did.
I HAVE A ASUS A8N 32 MOTHERBOARD AND I WAS THINKING OF GETING A ASUS P5N32-E SLI PLUS. I LOOKED IT UP ON THIS SITE AND IT LOOKS GOOD BUT I WANT TO KNOW WHAT YOU THINK.
Unless you're planning on running SLI, I'd go with the ASUS P5K E or P5K E with WIFI, a P35 board with the same features and should be less expensive.
For that price, your entitled to a top overclocker. Try the Foxconn Mars. See
http://www.pcstats.com/NewsView.cfm?NewsID=64354
http://www.quantum-force.net/news/N000000011/
www.bjorn3d.com/read_pf.php?cID=1184
http://www.pcstats.com/articleview.cfm?articleid=2205&page=8
I would go for the more moderate
Abit AB9 Pro @$89 or Abit AB9 QuadGT @$129
Personally, I like pcstats for mobo reviews
http://www.pcstats.com/articlesearch.cfm?SearchValue=&Search=Search&Category=175&CategorySearch=Get+Listing&sort=date
