Help cleaning built up dirt
FastGunna
532
I live on a dirt road in a house that is far from sealed so dust builds up quick. Normally I clean it every 2 weeks which has been working but I missed a cleaning because I was out of air dusters. What I didn't realise is that 3 weeks is all it takes to build up to the point that the dusters just don't cut it.
So first off, I need help getting the built up dirt off, most of it is in non important areas but I'm mostly concerned about the top of the GPU.
Secondly I'm looking for a cheaper alternative to air dusters. I think i saw a refillable one once but haven't been able to find one.
I actually did build with positive pressure in mind, however I don't have enough + to make up for the hole in the top. I plan on getting an h100i before summer rolls around and that might help (by filling the hole). I'm using a Storm Scout 2 case.
I might be building a PC for my dad in the not so distant future, what would be the best case to keep dirt out for under $70?
