Archived from groups: alt.games.thief-dark-project (
More info?)
In message <cu14qo3wsk9.fsf@nokia.com>, Darin Johnson
<darin_@_usa_._net> writes
>Some clock tower spoilers perhaps...
>I had initially "finished" with only 87% of the loot, and only 2 of 3
>special items, thus forcing me to retrace my steps and eventually
>reclimb the tower (I'm not sure if it was quicker to do that or to
>actually replay the second half from an earlier save game). One
>treasure was nearly impossible to see especially with loot glint
>turned down, one was in a chest I had already opened but was too dim
>to notice first time, and the final piece of special loot that was
>easier to pick up than to actually see.
>I seriously would not have found the last piece of loot without my
>knowing which room it existed in, and I only knew that because I was
>frustrated and went to a web site to see if it was physically possible
>to reclimb the tower and stumbled across the location by mistake.
>Even then it took well over an hour for me to locate it, and a lot of
>wasted time spent trying to reach a dark blob that turned out to be
>just part of the wood texture.
I've posted elsewhere that I finished today, starting again from the
top, and to my amazement got the lot. I think the reason was that I
played in T2 mode. I started looking in 'T2' places (like under desks)
and didn't rely on the glitter fairy, who can lure you into bad ways.
A piece of loot that is supposed to be hard to get isn't, I've found,
because there's a 'sort of' bug. What Garret can and can't do with his
climbing gloves is a bit arbitrary sometimes, and....
spoiler....
....to get to the one piece of loot in the high room , you only need to
get onto the section of wall the to right of it, which is do-able higher
up without difficulty. Garrett drops onto the ledge and, um, slides
*through* the raised stone divider. I've done it twice. It's a kind of
bug, because he seems to go through the stone; on the other hand, in
real life he would be able to negotiate that small divider easily
enough. If it comes to that, he'd be able to shimmy up those chains,
too
Terry Pratchett
