Help color settings for ASUS VC239h
Tristan Sam
51
Any color settings/calibration suggestion with this new monitor with less reviews for graphic design and color consistency to majority of monitors?
My GPU is Sapphire R9 280X
Monitor: ASUS VC239H
What made you say that? I would like to know more. *edit* also i do not have "movie picture preset, but i have scenery and theatre.
also in the windows color management what would be my setting?
Thanks for your response.
Theatre is super blueish.(on color temp its on 'cool') bit of doubtful about this. Is this color preset same(or atleast) with all monitors?
I am wondering what do apple/ios/mac have their color calibrated. 🙁 my current employer is using a iOS Yosemite and keep saying different colors(compared to him and mine)
*update* and about sRGB mode, is there any good in this preset?
apple calibrate their screens. well. then i cant tell you what you should change, it should default to warm, but definitely not blue.
use this an ask ASUS directly: https://secure.livechatinc.com/licence/1792571/open_chat.cgi?groups=54
you do not need a case number, just fill out the form and itll connect you to a ASUS employe. the reason i cant do it is because i dont know the serial #.
thanks. great help!
