Help Comment on my first build. THX!
Wen Tyng
Commendable
Oct 4, 2016
11
Hello, everyone, I am a new builder,can you give me some comment for my build?
-MSI B150M Night Elf
-Intel Core i5 6600
-CM Hyper212X
-Nvidia GTX1060 6GB
-2x Cosair DDR4 8GB RAM
-CM Elite V2 550W PSU
-CM Mid Tower K280(Dual USB3.0)
-120GB SSD & 1TB HDD
Wen Tyng
Commendable
Oct 4, 2016
11
Hello, should i pick a better PSU as this PSU is only 80Plus Bronze
GameFreak01048
694
You could go with a 80+ Gold PSU for more reliability of course :)
Wen Tyng
Commendable
Oct 4, 2016
11
Hmm...so if i dont change, will it affect the performance of the pc?
GameFreak01048
694
No, it will only effect the reliability of your PC, the higher the grade, the better but to keep costs down, gold is better :)
Wen Tyng
Commendable
Oct 4, 2016
11
[/quotemsg]
No, it will only effect the reliability of your PC, the higher the grade, the better but to keep costs down, gold is better :)[/quotemsg] OK, THank You Very Much!
bignastyid
80 plus rating has nothing to do with reliability. There are 80-plus gold PSUs that are junk and there are 80 plus bronze units that are good. 80 plus is simply an efficiency rating.
bignastyid
That PSU is very low quality and a potential danger to the rest of the system. The PSU is not a good place to skimp and not a lesson you want to learn the hardway. If needed drop the CM 212 and use the stock Intel cooler and use that money to get a better quality PSU. A good quality 430w PSU could run those specs with no problem. Here's a couple reccomendations.
http://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na
http://pcpartpicker.com/product/TgW9TW/seasonic-power-supply-m12ii520bronze
http://pcpartpicker.com/product/Cb7wrH/seasonic-power-supply-ssp450rt
http://pcpartpicker.com/product/kz7CmG/evga-power-supply-210gq0650
What bignastyid said.
Rating does not equal quality.
@OP, there are some very poor quality component choices in there, what is your budget?
If you are overseas, what retailers are you using?
I suggest you unselect the best answer by the way, not solved yet, it'll help more people get on this thread.
Wen Tyng
Commendable
Oct 4, 2016
11
Thanks for your opinion, I know what to do now
Wen Tyng
Commendable
Oct 4, 2016
11
Hmm, which one is poor quality component? Im Malaysian, my budget is RM 4400, its about 1040 USD
Branchingsalmon
29
Well that's a great PC for the first build, better than mine for sure, the only thing I would say is I would have gone with a 250 gigabyte ssd and Two, Three or maybe even four terabyte hard drive just so I have that extra storage and don't have to worry about slowing down.
Aaaay, i'm half Malaysian. :p
What retailers are you using?
