HELP: Computer dosen't detect Monitor's Displayport [No Signal]
dekanghazi
Hello. Yesterday I bought Predator XB271H 144hz monitor. It had a DisplayPort with it, so I know i'm not using a bad one. My PC is also a Predator. My GPU is Nvidia GeForce 1060 6GB. I have another monitor that works perfectly with VGA since my PC Doesnt have a HDMI port. When I connect the Displayport to my Monitor and my to my PC, but it says No signal. When I use HDMI it works but its only 60hz if i use HDMI, thats why I want to use Displayport.
Things I have tried.
Put Power supply to High Performance.
Turned off my Monitor and PC For 30 seconds.
Turned my Monitor off for 10 minutes.
Checked all Nvidia settings while using the new monitor with HDMI.
Please help me.
That doesnt make sense.. All 3 should be connected to GPU or.. why would they be there.. Wasnt the problem that the monitor was set to try read signal from different display port for example DP 3 while you had it in DP 1 ? Or theres some driver/setting problem probably
