Help computer hdmi gaming problems and i dont have my computer connected to my tv
Helpme11111
9
Every time i try to play a game on my computer in around ten minutes the screen turns blue and it says Hdmi lost connection than it makes a buzzing sound and restarts my pc the weird thing is that i don't have my computer connected to my tv
Not sure what your TV as to do with this. If it's not connected to your computer, then I don't know why it's being brought up. :)
Laptop or desktop?
Is your computer overheating?
What GPU/CPU do you have?
What are your temps?
Download HWINFO and MSI Afterburner. They'll display your temperatures; after you get them, post them. If your PC is shutting off after ten minutes of gaming, it sounds like you have an overheating problem.
anyway thanks for the help
Yes, you are overheating. You need to repaste your GPU/CPU, depending on which is overheating. Look up thermal paste tutorials on YouTube or this forum. Plenty of good ones that will show you how to do it much better than I can describe.
