Help Computer keeps Crashing
IntoDarkness
Commendable
May 18, 2016
28
Hello,
I'm unsure what the cause of this would be.
The issue started with a 'no video' error where the screen would just go blank and tell me that there was no video, the computer didn't shut down the screen just went blank.
That's stopped completely, now It's a full crash. It doesn't matter what I'm doing I could be playing a game or browsing the internet and it doesn't matter what temperature my room is, it just crashes.
Every time it crashes this error gets reported.
Log Name: Security
Source: Microsoft-Windows-Eventlog
Date: 8/8/2016 2:51:04 PM
Event ID: 1101
Task Category: Event processing
Level: Error
Keywords: Audit Success
User: N/A
Computer: DESKTOP-ET7P2OI
Description:
Audit events have been dropped by the transport. 0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Eventlog" Guid="{fc65ddd8-d6ef-4962-83d5-6e5cfe9ce148}" />
<EventID>1101</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>101</Task>
<Opcode>0</Opcode>
<Keywords>0x4020000000000000</Keywords>
<TimeCreated SystemTime="2016-08-08T20:51:04.421154000Z" />
<EventRecordID>1269</EventRecordID>
<Correlation />
<Execution ProcessID="1600" ThreadID="2180" />
<Channel>Security</Channel>
<Computer>DESKTOP-ET7P2OI</Computer>
<Security />
</System>
<UserData>
<AuditEventsDropped xmlns="http://manifests.microsoft.com/win/2004/08/windows/eventlog">
<Reason>0</Reason>
</AuditEventsDropped>
</UserData>
</Event>
I've tried
1. Cleaning my PC (Around 10 times in the past week.)
2. Checking my +12v, which stays at 12.192. (The number never changes)
3. Switching which PCIe slot my graphics card is in.
4. Manually setting my fan speed.
5. Reinstalling Windows.
6. Resetting my computer.
7. Scanning for viruses.
8. Installing new BIOS.
9. Reinstalling my GPU drivers.
10. Re-applying thermal paste on my CPU.
11. Adjusting my fan placement.
There is no way for me to test the parts in another PC.
Please, if you have any questions ask, I want this problem fixed as soon as possible.
Specs
CPU: Intel i7 6700k
CPU Cooler: Dark Rock Pro 3
GPU: Evga 970 SSC
Ram: G.Skill Ripjaws V 16gb
PSU: Evga Supernova 1000w Gold plus
Mobo: Asus ROG Maximus viii hero
OS: Windows 10 Home
Yes, sorry it's the Asus ROG Maximus VIII Hero, not the VII.
Ok, I will try and force a crash and get back to you.
There are four dump files which are these two repeated.
1.
On Mon 8/8/2016 8:53:54 AM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\080816-27187-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x149F90)
Bugcheck code: 0x9F (0x3, 0xFFFFDB8F6A5E7060, 0xFFFFF80090DEC8E0, 0xFFFFDB8F71050700)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
2.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
I havn't been able to force a crash, as I don't know what causes it, but, I've gone through and updated all of my drivers.
AI charger comes with AI suite 3, which is installed if you download the motherboards drivers from its disk. I've never used it, just plugged my phone in and it's charging.
Alright, but I doubt it's what the crash is caused from, as I downloaded the drivers off of the disk to try and fix the crash.
k see if it crashes now. Gigabyte have a similar program called On/Off charge.
Which does the same thing and can cause the same stop error. I dont know why they make programs like this.
USB ports can't handle what these programs are made to do.
It's like owning a mini and pretending it's a Ferrari lol. It's not going to happen
Got my new graphics card today... But display driver crashes have come back. I've cleanly updated my drivers, re-installed windows and it's still crashing.
On Sat 8/13/2016 3:34:46 AM GMT your computer crashed
This was probably caused by the following module: Unknown (0xFFFFFFFFC0000094)
Bugcheck code: 0x7E (0xFFFFFFFFC0000094, 0xFFFFF80838B2BFFA, 0xFFFFD3007E527FA8, 0xFFFFD3007E5277D0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch.
A third party driver was identified as the probable root cause of this system error.
Google query: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
