Hi guys I wiould like to get some help configuring OpenVPN server. I use the custom VPS server and there deployed an VPN server. So After configuring it I still get some strange error.
Here's my server.conf:
port 443
proto tcp
dev tun
ca /ect/openvpn/ca.crt
cert /etc/openvpn/server.crt
key /etc/openvpn/server.key # This file should be kept secret
dh dh2048.pem
server 10.8.0.0 255.255.255.0
ifconfig-pool-persist ipp.txt
push "redirect-gateway def1 bypass-dhcp"
push "dhcp-option DNS 208.67.222.222"
push "dhcp-option DNS 208.67.220.220"
keepalive 10 120
cipher AES-256-CBC # AES
comp-lzo
user nobody
group nogroup
persist-key
persist-tun
status openvpn-status.log
log /var/log/openvpn.log
verb 7
And Here's my Client.ovpn. On client side I use Windows 7 system.
client
dev tap
proto tcp
remote 107.155.114.172 443
resolv-retry infinite
nobind
persist-key
persist-tun
ca C:\\OVPN\\ca.crt
cert C:\\OVPN\\Vlad1.crt
key C:\\OVPN\\Vlad1.key
ns-cert-type server
cipher AES-256-CBC
comp-lzo
verb 7
And when I try to connect to my VPN server from windows 7 user, I get the following error, see log:
Im more concerned about following lines:
Mon May 30 08:58:10 2016 us=217774 Local Options hash (VER=V4): '44fbca6b'
Mon May 30 08:58:10 2016 us=217774 Expected Remote Options hash (VER=V4): '570d8093'
I dont know what's the solution here, can anyone help me with this?
Big thanks!
port 443
proto tcp
dev tun
dh dh2048.pem
keepalive 10 120
comp-lzo
user nobody
group nogroup
persist-key
persist-tun
verb 7
client
dev tap
proto tcp
nobind
persist-key
persist-tun
ca C:\\OVPN\\ca.crt
ns-cert-type server
cipher AES-256-CBC
comp-lzo
verb 7
Code:
Mon May 30 08:58:09 2016 us=463731 Current Parameter Settings:
Mon May 30 08:58:09 2016 us=464731 config = 'Vlad1.ovpn'
Mon May 30 08:58:09 2016 us=464731 mode = 0
Mon May 30 08:58:09 2016 us=464731 show_ciphers = DISABLED
Mon May 30 08:58:09 2016 us=464731 show_digests = DISABLED
Mon May 30 08:58:09 2016 us=464731 show_engines = DISABLED
Mon May 30 08:58:09 2016 us=464731 genkey = DISABLED
Mon May 30 08:58:09 2016 us=464731 key_pass_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 show_tls_ciphers = DISABLED
Mon May 30 08:58:09 2016 us=464731 Connection profiles [default]:
Mon May 30 08:58:09 2016 us=464731 proto = tcp-client
Mon May 30 08:58:09 2016 us=464731 local = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 local_port = 0
Mon May 30 08:58:09 2016 us=464731 remote = '107.155.114.172'
Mon May 30 08:58:09 2016 us=464731 remote_port = 443
Mon May 30 08:58:09 2016 us=464731 remote_float = DISABLED
Mon May 30 08:58:09 2016 us=464731 bind_defined = DISABLED
Mon May 30 08:58:09 2016 us=464731 bind_local = DISABLED
Mon May 30 08:58:09 2016 us=464731 connect_retry_seconds = 5
Mon May 30 08:58:09 2016 us=464731 connect_timeout = 10
Mon May 30 08:58:09 2016 us=464731 connect_retry_max = 0
Mon May 30 08:58:09 2016 us=464731 socks_proxy_server = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 socks_proxy_port = 0
Mon May 30 08:58:09 2016 us=464731 socks_proxy_retry = DISABLED
Mon May 30 08:58:09 2016 us=464731 tun_mtu = 1500
Mon May 30 08:58:09 2016 us=464731 tun_mtu_defined = ENABLED
Mon May 30 08:58:09 2016 us=464731 link_mtu = 1500
Mon May 30 08:58:09 2016 us=464731 link_mtu_defined = DISABLED
Mon May 30 08:58:09 2016 us=464731 tun_mtu_extra = 32
Mon May 30 08:58:09 2016 us=464731 tun_mtu_extra_defined = ENABLED
Mon May 30 08:58:09 2016 us=464731 mtu_discover_type = -1
Mon May 30 08:58:09 2016 us=464731 fragment = 0
Mon May 30 08:58:09 2016 us=464731 mssfix = 1450
Mon May 30 08:58:09 2016 us=464731 explicit_exit_notification = 0
Mon May 30 08:58:09 2016 us=464731 Connection profiles END
Mon May 30 08:58:09 2016 us=464731 remote_random = DISABLED
Mon May 30 08:58:09 2016 us=464731 ipchange = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 dev = 'tap'
Mon May 30 08:58:09 2016 us=464731 dev_type = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 dev_node = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 lladdr = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 topology = 1
Mon May 30 08:58:09 2016 us=464731 tun_ipv6 = DISABLED
Mon May 30 08:58:09 2016 us=464731 ifconfig_local = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 ifconfig_remote_netmask = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 ifconfig_noexec = DISABLED
Mon May 30 08:58:09 2016 us=464731 ifconfig_nowarn = DISABLED
Mon May 30 08:58:09 2016 us=464731 ifconfig_ipv6_local = '[UNDEF]'
Mon May 30 08:58:09 2016 us=464731 ifconfig_ipv6_netbits = 0
Mon May 30 08:58:09 2016 us=465731 ifconfig_ipv6_remote = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 shaper = 0
Mon May 30 08:58:09 2016 us=465731 mtu_test = 0
Mon May 30 08:58:09 2016 us=465731 mlock = DISABLED
Mon May 30 08:58:09 2016 us=465731 keepalive_ping = 0
Mon May 30 08:58:09 2016 us=465731 keepalive_timeout = 0
Mon May 30 08:58:09 2016 us=465731 inactivity_timeout = 0
Mon May 30 08:58:09 2016 us=465731 ping_send_timeout = 0
Mon May 30 08:58:09 2016 us=465731 ping_rec_timeout = 0
Mon May 30 08:58:09 2016 us=465731 ping_rec_timeout_action = 0
Mon May 30 08:58:09 2016 us=465731 ping_timer_remote = DISABLED
Mon May 30 08:58:09 2016 us=465731 remap_sigusr1 = 0
Mon May 30 08:58:09 2016 us=465731 persist_tun = ENABLED
Mon May 30 08:58:09 2016 us=465731 persist_local_ip = DISABLED
Mon May 30 08:58:09 2016 us=465731 persist_remote_ip = DISABLED
Mon May 30 08:58:09 2016 us=465731 persist_key = ENABLED
Mon May 30 08:58:09 2016 us=465731 passtos = DISABLED
Mon May 30 08:58:09 2016 us=465731 resolve_retry_seconds = 1000000000
Mon May 30 08:58:09 2016 us=465731 username = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 groupname = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 chroot_dir = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 cd_dir = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 writepid = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 up_script = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 down_script = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 down_pre = DISABLED
Mon May 30 08:58:09 2016 us=465731 up_restart = DISABLED
Mon May 30 08:58:09 2016 us=465731 up_delay = DISABLED
Mon May 30 08:58:09 2016 us=465731 daemon = DISABLED
Mon May 30 08:58:09 2016 us=465731 inetd = 0
Mon May 30 08:58:09 2016 us=465731 log = ENABLED
Mon May 30 08:58:09 2016 us=465731 suppress_timestamps = DISABLED
Mon May 30 08:58:09 2016 us=465731 nice = 0
Mon May 30 08:58:09 2016 us=465731 verbosity = 7
Mon May 30 08:58:09 2016 us=465731 mute = 0
Mon May 30 08:58:09 2016 us=465731 gremlin = 0
Mon May 30 08:58:09 2016 us=465731 status_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 status_file_version = 1
Mon May 30 08:58:09 2016 us=465731 status_file_update_freq = 60
Mon May 30 08:58:09 2016 us=465731 occ = ENABLED
Mon May 30 08:58:09 2016 us=465731 rcvbuf = 0
Mon May 30 08:58:09 2016 us=465731 sndbuf = 0
Mon May 30 08:58:09 2016 us=465731 sockflags = 0
Mon May 30 08:58:09 2016 us=465731 fast_io = DISABLED
Mon May 30 08:58:09 2016 us=465731 lzo = 7
Mon May 30 08:58:09 2016 us=465731 route_script = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 route_default_gateway = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 route_default_metric = 0
Mon May 30 08:58:09 2016 us=465731 route_noexec = DISABLED
Mon May 30 08:58:09 2016 us=465731 route_delay = 5
Mon May 30 08:58:09 2016 us=465731 route_delay_window = 30
Mon May 30 08:58:09 2016 us=465731 route_delay_defined = ENABLED
Mon May 30 08:58:09 2016 us=465731 route_nopull = DISABLED
Mon May 30 08:58:09 2016 us=465731 route_gateway_via_dhcp = DISABLED
Mon May 30 08:58:09 2016 us=465731 max_routes = 100
Mon May 30 08:58:09 2016 us=465731 allow_pull_fqdn = DISABLED
Mon May 30 08:58:09 2016 us=465731 management_addr = '127.0.0.1'
Mon May 30 08:58:09 2016 us=465731 management_port = 25340
Mon May 30 08:58:09 2016 us=465731 management_user_pass = 'stdin'
Mon May 30 08:58:09 2016 us=465731 management_log_history_cache = 250
Mon May 30 08:58:09 2016 us=465731 management_echo_buffer_size = 100
Mon May 30 08:58:09 2016 us=465731 management_write_peer_info_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 management_client_user = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 management_client_group = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 management_flags = 6
Mon May 30 08:58:09 2016 us=465731 shared_secret_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 key_direction = 0
Mon May 30 08:58:09 2016 us=465731 ciphername_defined = ENABLED
Mon May 30 08:58:09 2016 us=465731 ciphername = 'AES-256-CBC'
Mon May 30 08:58:09 2016 us=465731 authname_defined = ENABLED
Mon May 30 08:58:09 2016 us=465731 authname = 'SHA1'
Mon May 30 08:58:09 2016 us=465731 prng_hash = 'SHA1'
Mon May 30 08:58:09 2016 us=465731 prng_nonce_secret_len = 16
Mon May 30 08:58:09 2016 us=465731 keysize = 0
Mon May 30 08:58:09 2016 us=465731 engine = DISABLED
Mon May 30 08:58:09 2016 us=465731 replay = ENABLED
Mon May 30 08:58:09 2016 us=465731 mute_replay_warnings = DISABLED
Mon May 30 08:58:09 2016 us=465731 replay_window = 64
Mon May 30 08:58:09 2016 us=465731 replay_time = 15
Mon May 30 08:58:09 2016 us=465731 packet_id_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 use_iv = ENABLED
Mon May 30 08:58:09 2016 us=465731 test_crypto = DISABLED
Mon May 30 08:58:09 2016 us=465731 tls_server = DISABLED
Mon May 30 08:58:09 2016 us=465731 tls_client = ENABLED
Mon May 30 08:58:09 2016 us=465731 key_method = 2
Mon May 30 08:58:09 2016 us=465731 ca_file = 'C:\OVPN\ca.crt'
Mon May 30 08:58:09 2016 us=465731 ca_path = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 dh_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 cert_file = 'C:\OVPN\Vlad1.crt'
Mon May 30 08:58:09 2016 us=465731 extra_certs_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 priv_key_file = 'C:\OVPN\Vlad1.key'
Mon May 30 08:58:09 2016 us=465731 pkcs12_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 cryptoapi_cert = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 cipher_list = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 tls_verify = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 tls_export_cert = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 verify_x509_type = 0
Mon May 30 08:58:09 2016 us=465731 verify_x509_name = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 crl_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 ns_cert_type = 1
Mon May 30 08:58:09 2016 us=465731 remote_cert_ku[i] = 0
Mon May 30 08:58:09 2016 us=465731 remote_cert_eku = '[UNDEF]'
Mon May 30 08:58:09 2016 us=465731 ssl_flags = 0
Mon May 30 08:58:09 2016 us=466731 tls_timeout = 2
Mon May 30 08:58:09 2016 us=466731 renegotiate_bytes = 0
Mon May 30 08:58:09 2016 us=466731 renegotiate_packets = 0
Mon May 30 08:58:09 2016 us=466731 renegotiate_seconds = 3600
Mon May 30 08:58:09 2016 us=466731 handshake_window = 60
Mon May 30 08:58:09 2016 us=466731 transition_window = 3600
Mon May 30 08:58:09 2016 us=466731 single_session = DISABLED
Mon May 30 08:58:09 2016 us=466731 push_peer_info = DISABLED
Mon May 30 08:58:09 2016 us=466731 tls_exit = DISABLED
Mon May 30 08:58:09 2016 us=466731 tls_auth_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=466731 pkcs11_protected_authentication = DISABLED
Mon May 30 08:58:09 2016 us=466731 pkcs11_private_mode = 00000000
Mon May 30 08:58:09 2016 us=466731 pkcs11_cert_private = DISABLED
Mon May 30 08:58:09 2016 us=466731 pkcs11_pin_cache_period = -1
Mon May 30 08:58:09 2016 us=466731 pkcs11_id = '[UNDEF]'
Mon May 30 08:58:09 2016 us=466731 pkcs11_id_management = DISABLED
Mon May 30 08:58:09 2016 us=466731 server_network = 0.0.0.0
Mon May 30 08:58:09 2016 us=466731 server_netmask = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 server_network_ipv6 = ::
Mon May 30 08:58:09 2016 us=469732 server_netbits_ipv6 = 0
Mon May 30 08:58:09 2016 us=469732 server_bridge_ip = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 server_bridge_netmask = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 server_bridge_pool_start = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 server_bridge_pool_end = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 ifconfig_pool_defined = DISABLED
Mon May 30 08:58:09 2016 us=469732 ifconfig_pool_start = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 ifconfig_pool_end = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 ifconfig_pool_netmask = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 ifconfig_pool_persist_filename = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 ifconfig_pool_persist_refresh_freq = 600
Mon May 30 08:58:09 2016 us=469732 ifconfig_ipv6_pool_defined = DISABLED
Mon May 30 08:58:09 2016 us=469732 ifconfig_ipv6_pool_base = ::
Mon May 30 08:58:09 2016 us=469732 ifconfig_ipv6_pool_netbits = 0
Mon May 30 08:58:09 2016 us=469732 n_bcast_buf = 256
Mon May 30 08:58:09 2016 us=469732 tcp_queue_limit = 64
Mon May 30 08:58:09 2016 us=469732 real_hash_size = 256
Mon May 30 08:58:09 2016 us=469732 virtual_hash_size = 256
Mon May 30 08:58:09 2016 us=469732 client_connect_script = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 learn_address_script = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 client_disconnect_script = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 client_config_dir = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 ccd_exclusive = DISABLED
Mon May 30 08:58:09 2016 us=469732 tmp_dir = 'C:\Users\Admin\AppData\Local\Temp\'
Mon May 30 08:58:09 2016 us=469732 push_ifconfig_defined = DISABLED
Mon May 30 08:58:09 2016 us=469732 push_ifconfig_local = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 push_ifconfig_remote_netmask = 0.0.0.0
Mon May 30 08:58:09 2016 us=469732 push_ifconfig_ipv6_defined = DISABLED
Mon May 30 08:58:09 2016 us=469732 push_ifconfig_ipv6_local = ::/0
Mon May 30 08:58:09 2016 us=469732 push_ifconfig_ipv6_remote = ::
Mon May 30 08:58:09 2016 us=469732 enable_c2c = DISABLED
Mon May 30 08:58:09 2016 us=469732 duplicate_cn = DISABLED
Mon May 30 08:58:09 2016 us=469732 cf_max = 0
Mon May 30 08:58:09 2016 us=469732 cf_per = 0
Mon May 30 08:58:09 2016 us=469732 max_clients = 1024
Mon May 30 08:58:09 2016 us=469732 max_routes_per_client = 256
Mon May 30 08:58:09 2016 us=469732 auth_user_pass_verify_script = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 auth_user_pass_verify_script_via_file = DISABLED
Mon May 30 08:58:09 2016 us=469732 client = ENABLED
Mon May 30 08:58:09 2016 us=469732 pull = ENABLED
Mon May 30 08:58:09 2016 us=469732 auth_user_pass_file = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 show_net_up = DISABLED
Mon May 30 08:58:09 2016 us=469732 route_method = 0
Mon May 30 08:58:09 2016 us=469732 block_outside_dns = DISABLED
Mon May 30 08:58:09 2016 us=469732 ip_win32_defined = DISABLED
Mon May 30 08:58:09 2016 us=469732 ip_win32_type = 3
Mon May 30 08:58:09 2016 us=469732 dhcp_masq_offset = 0
Mon May 30 08:58:09 2016 us=469732 dhcp_lease_time = 31536000
Mon May 30 08:58:09 2016 us=469732 tap_sleep = 0
Mon May 30 08:58:09 2016 us=469732 dhcp_options = DISABLED
Mon May 30 08:58:09 2016 us=469732 dhcp_renew = DISABLED
Mon May 30 08:58:09 2016 us=469732 dhcp_pre_release = DISABLED
Mon May 30 08:58:09 2016 us=469732 dhcp_release = DISABLED
Mon May 30 08:58:09 2016 us=469732 domain = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 netbios_scope = '[UNDEF]'
Mon May 30 08:58:09 2016 us=469732 netbios_node_type = 0
Mon May 30 08:58:09 2016 us=469732 disable_nbt = DISABLED
Mon May 30 08:58:09 2016 us=469732 OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on May 10 2016
Mon May 30 08:58:09 2016 us=470732 Windows version 6.1 (Windows 7) 64bit
Mon May 30 08:58:09 2016 us=470732 library versions: OpenSSL 1.0.1t 3 May 2016, LZO 2.09
Enter Management Password:
Mon May 30 08:58:09 2016 us=480732 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Mon May 30 08:58:09 2016 us=480732 Need hold release from management interface, waiting...
Mon May 30 08:58:09 2016 us=908757 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Mon May 30 08:58:10 2016 us=8762 MANAGEMENT: CMD 'state on'
Mon May 30 08:58:10 2016 us=8762 MANAGEMENT: CMD 'log all on'
Mon May 30 08:58:10 2016 us=85767 MANAGEMENT: CMD 'hold off'
Mon May 30 08:58:10 2016 us=86767 MANAGEMENT: CMD 'hold release'
Mon May 30 08:58:10 2016 us=217774 PRNG init md=SHA1 size=36
Mon May 30 08:58:10 2016 us=217774 crypto_adjust_frame_parameters: Adjusting frame parameters for crypto by zu bytes
Mon May 30 08:58:10 2016 us=217774 LZO compression initialized
Mon May 30 08:58:10 2016 us=217774 PID packet_id_init tcp_mode=1 seq_backtrack=64 time_backtrack=15
Mon May 30 08:58:10 2016 us=217774 Control Channel MTU parms [ L:1592 D:1210 EF:40 EB:0 ET:0 EL:3 ]
Mon May 30 08:58:10 2016 us=217774 MTU DYNAMIC mtu=1450, flags=2, 1592 -> 1450
Mon May 30 08:58:10 2016 us=217774 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon May 30 08:58:10 2016 us=217774 RESOLVE_REMOTE flags=0x0101 phase=1 rrs=0 sig=-1 status=0
Mon May 30 08:58:10 2016 us=217774 Data Channel MTU parms [ L:1592 D:1450 EF:60 EB:143 ET:32 EL:3 AF:3/1 ]
Mon May 30 08:58:10 2016 us=217774 Local Options String: 'V4,dev-type tap,link-mtu 1592,tun-mtu 1532,proto TCPv4_CLIENT,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
Mon May 30 08:58:10 2016 us=217774 Expected Remote Options String: 'V4,dev-type tap,link-mtu 1592,tun-mtu 1532,proto TCPv4_SERVER,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
Mon May 30 08:58:10 2016 us=217774 Attempting to establish TCP connection with [AF_INET]107.155.114.172:443 [nonblock]
Mon May 30 08:58:10 2016 us=217774 MANAGEMENT: >STATE:1464587890,TCP_CONNECT,,,
Mon May 30 08:58:20 2016 us=219346 TCP: connect to [AF_INET]107.155.114.172:443 failed, will try again in 5 seconds: Connection timed out (WSAETIMEDOUT)
Mon May 30 08:58:25 2016 us=219632 MANAGEMENT: >STATE:1464587905,TCP_CONNECT,,,
Mon May 30 08:58:35 2016 us=221205 TCP: connect to [AF_INET]107.155.114.172:443 failed, will try again in 5 seconds: Connection timed out (WSAETIMEDOUT)
Mon May 30 08:58:40 2016 us=221491 MANAGEMENT: >STATE:1464587920,TCP_CONNECT,,,
Mon May 30 08:58:45 2016 us=223777 PID packet_id_free
Mon May 30 08:58:45 2016 us=223777 TCP/UDP: Closing socket
Mon May 30 08:58:45 2016 us=223777 SIGTERM[hard,init_instance] received, process exiting
Mon May 30 08:58:45 2016 us=223777 MANAGEMENT: >STATE:1464587925,EXITING,init_instance,,
Mon May 30 08:58:45 2016 us=224777 PKCS#11: Terminating openssl
Mon May 30 08:58:45 2016 us=224777 PKCS#11: Removing providers
Mon May 30 08:58:45 2016 us=224777 PKCS#11: Releasing sessions
Mon May 30 08:58:45 2016 us=224777 PKCS#11: Terminating slotevent
Mon May 30 08:58:45 2016 us=224777 PKCS#11: Marking as uninitialized
Mon May 30 08:58:45 2016 us=224777 Closing Win32 semaphore 'openvpn_netcmd'
Big thanks!
