Question Help connecting 2 case Fans RGB in daisy chain
emm
23
5
18,515
I just brought 2 case fans coolermaster sickleflow V2 RGB. The fans have 3 connectors 1 pwm power connector and 2 RGB connectors 4 pin one Male and one Female, I already have connected 1 fan to my motherboard header RGB but the other fan I only connected the pwm power so both fans are working but there is one fan that I haven't connected to the RGB header. Can I daisy chain both fans with the female and male RGB 4 pin connectors that they came or I still need an RGB splitter to connect the fans to the only header in my mother board?
First understand that while you may have just a fan physically, realistically you have 2 different things. You have the fan and the lights. They aren't the same, just happen to be mounted on the same frame. So daisy chaining for the fan is a seperate thing from daisy chaining for the RGB lighting.
If the fans both work, ignore that, ignore any pwm, fan header, settings, none of it applies or is relevant. So you have 2 RGB lights, that's all that needs addressing.
So you have RGB into the first light, there's an identical RGB input on the other light, and an RGB output also on the first light. So assume that the lights will in fact daisy chain, into the first light, then out to the second light.
Yes sorry for the misunderstanding my concern is about the RGB connections because I have 2 connectors on each fan one male and one female I just need to know if I can connect the RGB female to the board RGB and the male to the next Fan so both will turn RGB leds ON right now I have one RGB led on the other one is disconnected.
