Help! Connecting a USB-b to a parallel socket
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    ATI
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
OK, here's a hard one. I need some advice.
I own a D-Link wireless printer server with a parallel printer socket.
I want to buy a new printer but everything sold today only features
USB. So, essentially I need to connect a USB-b (printer-end USB) to a
parallel socket.
To be blatantly obvious:
Printer (USB) --- wireless print server (parallel only) ------- laptop.
Thank in advance for the help.
<ebakunin@gmail.com> wrote in message
news:1104454548.174941.113960@z14g2000cwz.googlegroups.com...
> parallel socket.
There are converters that would allow printing to a parallel printer from a USB
port but not vice versa.
An alternative would be to get a printer such as a DeskJet 5650 or 6540 that
have parallel ports or units such as a DeskJet 5850 or 6840 that have built in
802.11b wireless networking. The price differential for the printer is less
than the cost of an external USB server. See:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/18972-236251-236261-14438-f51-304441.html,
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/18972-236251-236261-14438-f51-357210.html,
or
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/18972-236251-236261-14438-f51-385457.html.
Regards,
Bob Headrick, not speaking for my employer HP
> parallel socket.
You'd better give up. These are two completely different interfaces, they
communicate in an entirely different way. This is not a matter of matching
the right pair of wires... You get the point? :)
http://www.ramelectronics.net/html/usb_printer_cable.htm?source=findwhat
http://www.usbport.com/
http://www.cablesdirect.com/search_result3.asp?txtKeyword=UC-1284GB&txtName=USB+to+Parallel+Printer+Cables
http://inktomi-cnet.com.com/Targus_USB_to_Parallel_Adapter/4014-3380_9-20294070.html?part=inktomi-cnet&subj=Targus+USB+to+Parallel+Adapter&tag=feed
Lots of choices out there to convert from USB to Parallel. Just Google for
"USB to Parallel"
Bob S.
> parallel socket.
Just a slight correction - the HP 6540 does not have a parallel port.
Unless there are two versions of it. :)
"Bill" <bill@c.a> wrote in message news:4pGdnTmrrM9HoEjcRVn-pw@golden.net...
>>in
Oops - you are correct. I was getting confused with the 5550 and 5650 which
the 6540 superseded. Thanks for correcting my error.
Regards,
Bob Headrick
> parallel socket.
There are still quite a number of printers with Parallel as well as USB. For
instance mine - Canon ip4000 - very happy with it, I'm running it on USB,
but it also has a parallel connection. Shouldn't be that hard to find one
you're happy with (though I don't know what kind of printer you're after)
Well that's the first one I've seen from you, so being a new year and
all, we'll let that one go. :)
Happy New Year!
