Hi.
Newbie alert! Please be gentle🙂
I would like some advice about adding additional case fans to my PC build.
Here are my components:
Asus Z97M-Plus Micro ATX Motherboard
Intel Core i5 4670K Quad Core Retail CPU
Cooler Master Hyper 212 EVO
EVGA NVIDIA GTX 750Ti FTW with ACX Cooling
G.Skill 8GB (2x 4GB) Dual Channel Ares Series Memory Kit
Be Quiet! CM BQT L8-630W PSU
WD 1TB 3.5 inch Internal Hard Drive - Caviar Blue
Crucial CT240M500SSD1 2.5-inch 240GB SSD
Fractal Design Define Mini Series Micro ATX Case
Samsung 24x Retail SATA DVD Writer
Microsoft Windows 8.1
2x Fractal Design 120mm Silent Series R2 120mm fans
2 x GELID Solutions Slim 12 PL Blue Silent Slim 120mm PWM fans
I currently have 2 fans that came with the Fractal Design Define Mini case, they are 2 Fractal Design 120mm Silent Series R2 120mm. I would like to add 2 GELID Solutions Slim 12 PL Blue Silent Slim 120mm fans, but my motherboard only has 2 chassis fan connectors.
I know potential solutions are fan splitters, connecting direct to the PSU with a molex adapture etc.. but I'm still not 100% sure of the best option mainly because of my lack of knowledge regarding VOLTS, WATTS and AMPS. I'm worried I might overload the motherboard or mess-up the PSU.
What is the best option for the above build? Would attaching two fan splitters on to each chassis fan connector cause any problems? I currently have 2 of these fan splitters from Amazon UK Akasa PWN Fan Splitter Cable. Would these be suitable?
Any help or advice would be greatly received.
Best Regards,
Susan
Best Regards,
Susan
