Hello,
Not sure exactly where this belongs, but I'm putting it here as a start. I recently hooked up my xbox to my PC monitor using an HDMI to DVI adapter. It works fine, but the visuals don't appear to be in HD. The guide seems a bit fuzzy and Halo 4 seems to look worse on this screen than it does on my TV. I also don't have the "HDTV Settings" option like I would normally have when I use my Xbox on my TV. I know that DVI and HDMI are basically the same thing though, and am trying to figure out if maybe I'm just crazy or if theres a way I can improve the visual quality. For reference, here is the monitor I have-
http://www.amazon.com/gp/product/B [...] kfriday-20[1][1]
And this is the adapter I'm using-
http://www.interstatemusic.com/835 [...] 4Aodh1YA7A[2][2]
Any and all help is appreciated!
